ianwynne
Joined: 1/24/2007 From: SydneyNSW, AUSTRALIA Status: offline
Hello TCrafty: I was waiting for somebody to respond to my remark. I will explain why I'm hoping that the ST G51 carb will improve the performance of my OS 50sx. I want to use 5% nitro in my 50sx. However, with 5% nitro the low speed needle will not lean out sufficiently for a good idle. It's always too rich. If I screw the low speed needle in, if fouls against the carb body, then the throttle barrel will not close properly to shut off the engine. I'm a "newbie" and it took weeks at the flying field to work out what was happening with my 50sx. I think that with a G51 carb fitted, I will be able lean out the low speed needle sufficiently. I have tried using OS #F and OS A3 glow plugs in my 50sx, while the "hotter" plugs did improve the idle, it's still too rich. In contrast, I've found my Supertigres much easier to tune without endless fiddling with glow plugs and what not. I hope that make things a little clearer. Bye, Ian
