want to finally try gas
Tower Hobbies
Logged in as Guest
  Printable Version
Saito FA-120S Four Stroke Engine
Seller:  RCadmin
Details:   $285.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Fuji-Imvac Engines Support >> want to finally try gas
Page: [1]
Login
want to finally try gas - 3/6/2008 11:43:08 PM
dan4466
Status: online
I would like to try a Fuji 24 on a 1/4 scale Cub. This would be my first gas engine and I must admit I'm a little intimadated. I want to keep it as simple as possible. My main question is if I should go with an EI or will a magneto be a good choice. Also, I see that the Great Planes Kill switch doesn't work with Fuji EI engines as per TH web site. I'm even unsure how to hook up the switch and the Fuji manual doesn't mention how to at all.
Thanks for any help,
Dan
       Post #: 1
RE: want to finally try gas - 3/7/2008 6:55:06 PM
Bax
Status: offline
The EI unit will make the engine much easier to start with a flip. For a switch, you simply put a switch between the battery pack and the EI unit. If you have a manual switch, and a servo-operated one, you put them in series. Then, both have to be 'on' for the engine to run. Basically, you can use two radio-type switch harnesses in series and have two switches...then set up one to be servo-actuated.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to dan4466)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
