PylonWorld
NC, USA Status: offline
Ed, I tried the 1.5" spinner, and it could be done, but I'm going to leave it as is. Doing the 1.5" would require increasing the fuselage height. The real plane has a fairly large spinner, and there's no good reason to make it even less realistic. BTW, I subscribe to the "platetocovertheenginecompartmentaccesshole" club, and plan to use them whenever they make sense. When I saw Big Bruce's El Bandito, I went "Whoa, those are legal?". That's why I questioned the Contest board chairman about it, because I wanted to be sure I could use a platetocovertheenginecompartmentaccesshole. In my "rest" time, I'm drawing up a GR-7, aka Kazi Killer, and I will use the 1.5" on the Plastic Phantastic because the real one has a small spinner, and the nose is sloped enough to do it. Dan, I looked at the cross section again, and my calculations were based on using a 1.25" wide canopy and didn't include the fairings into the canopy. If I go to a 1.5" wide canopy I'll be ok with the current profile. It will be close, but I'll have to do some serious template and CAD work so that every bit is accounted for. BTW, I'm sure there are people out there who have referred to me as an "accesshole".
_____________________________
Don Stegall RCPRO Chairman of the Board
