theradioflyer
MI, USA Status: offline
Everything looks good, I can't think of other things except other things like different hardware. Collars and such are just bad and can't be trusted, at least on my first run T-6. Later version may have better hardware. Do you have a LHS near by? Weight issues are always a concern on planes. I took this into account when planning my T-6. I decided to go with 2 TP 2070, it fit for me because I use then separately on other planes, the weight is 12.1 ounces for both and add .6 ounces for the Y harness. Side by side these packs fit perfectly in the nose of the Texan. The weight of the TP 4200 is 10 ounces, a little lighter, but you'll need to add more weight to get it balanced. I had to put 3.3 ounces of lead on the firewall with my set-up to balance @ 4 1/8 inches behind the wheel well. The AUW on my Texan is 4#8.6 ounces.
_____________________________
I dig up so much dirt with the Prop, they call me the farmer.
