theradioflyer
MI, USA Status: online
Hey Brian, I do have flaps and use them. 10% for takeoff and 30% to land. If your using the Power 32 it doesn't seem like you need all of that weight, but who knows. I fly the rudder and no mix. Do you have an incident meter to check your wing to your stab? I have 2 clicks of down, no aileron, and 6 clicks of right rudder to fly straight. CG is 4 to 4 1/8" back from the front of the wheel openings. I never checked it after I installed the scale wheels and the E-Flite ESC. I hope you can get this bird figured out, it's spectacular to see flying around. I keep reading your first post trying to see if I'm missing anything, the only thing that stuck out in my mind was your previous planes. All of them will slow up MUCH more than this plane. When I turned on final today I was at half throttle. I didn't cut the throttle until my nose was pointed down and I crossed the "fence" at 10 feet up and that's starting full flaps on the downwind leg.. Normal flying is half to 3/4 with the Power 25, full throttle only on loops and rolls. This Texan has typical warbird traits. One more- I've read that you don't get a big power increase from the 25 to the 32 with a 3s battery, most are using 4s batts with the 32 in the Texan. I really hope I'm helping God Bless! Jay
< Message edited by theradioflyer -- 4/3/2008 3:29:21 AM >
_____________________________
I dig up so much dirt with the Prop, they call me the farmer.
