ChargerDude70
Joined: 3/2/2008 From: clinton township, MI, USA Status: offline
quote:
ORIGINAL: flyn hy I was told the CG is "on" the spar? Tube? Now I don't remember. As for the landing gear, I will probably go aluminum. Not sure I could afford (want to pay for) carbon fiber. ChargerDude70, who did you get your DL from? How does it run? I would like to recommend coating the engine area on your plane as it will soak up fuel like a sponge if left untreated. I use a solution of 30 min. epoxy and alcohol. I also will be coating the frame work from the firewall back as far as I can reach to seal the wood and add structural integrity. The plane is not top shelf but I didn't pay top shelf for it. Rick at Precision Hobby Products has been great to work with. Please keep posting as you are both further ahead and closer to flying these birds than I am. I purchased the engine from a member on this site...I paid 340.00 shipped. I havent ran it much...just about a 1/2 hour so far. Just breaking it in right now. I had to lower the idle on it substantially. other than that, good so far. I will take your advice on the painting of the engine compartment. As said before...the quality isnt quite there but you get what you pay for. With the cost of the extra 2 servos for the wings and the added cost for better hardware...hind sight says I'd rather gotten a SD or Areoworks. As stated before though, Rick has been very good as far as service or questions being answered. They just need to do a few tweeks(assembly manual...canopy cut out template)? I was told the CG is on the spar, plane right side up. When I went to balance, I had to move my batteries to the front. I have 2 6v 2700 Spektrum Nimh for radio and 1 6v 2700 Nimh for ignition. I also went with alum spinner for a little more weight. My prop is a PT model CF 23X8 for flight. I also am running a Smartfly system that I slaved to my choke servo. When on choke, there is no power to the ignition. Cant hurt to be too safe.
