pub
PA, USA Status: offline
This is a repair that will work.the problem with the bearing is that it will not release under pressure because of carbon build up,repair by removing the bearing(be careful not to loose it) grind flat spots 180 degs. and drill a .060 hole ,install with the hole facing the muffler spring.as a safety have the radio turned off,only while you drill the hole,because the radio waves can plug up the hole.The price of a radio wave drill is out of sight today,most bearing repair shops don't like to fix someone else work that is screwed up. pub
