RE: Muffler bearings problem, please help!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Lanier Taylorcraft (1/4) - ARC
Seller:  p38nut
Details:   $250.00   |  6/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Humor >> RE: Muffler bearings problem, please help!!!
Page: <<   < prev  1 2 3 4 5 [6] 7   next >   >>
Login
RE: Muffler bearings problem, please help!!! - 7/6/2009 5:06 AM
streetrodder
Score: 100
Last Login: 10/2/2012
Status: offline
Use sailboat fuel in your air plane it will keep the muffler bearings well lubed and keep them from going out.
_____________________________
"If it goes up and comes down very fast I'm flying it"
Hide Signatures
(in reply to rgm762)
       Post #: 126
RE: Muffler bearings problem, please help!!! - 8/10/2009 8:07 AM
qwertypemdas
Score: 115
Last Login: 12/24/2012
Status: offline
anyone tryed those oneway muffler bearings? The suck on bumpstarts but the reduce transfiguration of the muffler gasket. Are they really that good? If you lube them too much do they slip?
May your thumbs live long, and prosper.
Hide Signatures
(in reply to streetrodder)
       Post #: 127
RE: Muffler bearings problem, please help!!! - 8/10/2009 8:11 AM
qwertypemdas
Score: 115
Status: offline
http://kalecoauto.com/index.php?main_page=product_info&products_id=10&zenid=d4366386a685d028f8e3dfd3c04cb177 i tryed these but they wouldn't fit in my cox sure start muffler. I wish i had a tuned glow plug to balance out my crankshaft velcro.
Hide Signatures
(in reply to victorzamora)
       Post #: 128
RE: Muffler bearings problem, please help!!! - 8/10/2009 8:13 AM
qwertypemdas
Score: 115
Status: offline
http://kalecoauto.com/index.php?main_page=product_info&cPath=3&products_id=27 hmmmm. too expensive.
Hide Signatures
(in reply to qwertypemdas)
       Post #: 129
RE: Muffler bearings problem, please help!!! - 2/17/2010 11:53 PM
chunkyplunker
Score: 105
Last Login: 4/16/2013
Status: offline
quote:
ORIGINAL: Lomcevak Duck
You cheated!
I wonder how many people have actually done it with a PC.
Add one, I just had to try it, in my mind I knew better, but did it anyway.
Club Saito #678
Hide Signatures
(in reply to Lomcevak Duck)
       Post #: 130
RE: Muffler bearings problem, please help!!! - 2/19/2010 6:29 AM
LD24
Score: 100
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: saucerguy
My muffler bearings keep going out on me on my .40 engine, can anybody please advise me upon what I'm doing wrong?...........
Clean the inside of the muffler in a bucket of steam; then take about  six inches of chow line to dryout and polish the inside of the muffler (chowline is great for this kind of clean up and polish); and finally relube with true bearing grease available at your local US Navy surplus store...Caution...Don't use the relative bearing grease as it will not hold the bearings in their true position...
LLD
Hide Signatures
(in reply to saucerguy)
       Post #: 131
RE: Muffler bearings problem, please help!!! - 2/19/2010 6:37 AM
LD24
Score: 100
Status: offline
quote:
ORIGINAL: Bass1
Alot of people just don't know the proper technique in getting their bearings straight in the first place! Crooked bearings are just inviting problems.
It's probably because they have always relied on unreliable relative bearings and get confused when they upgrade to the true bearing that are much more reliable in keeping your bearing straight....
Larry Diamond, USN, Retired Chief
Hide Signatures
(in reply to Bass1)
       Post #: 132
RE: Muffler bearings problem, please help!!! - 2/19/2010 6:45 AM
LD24
Score: 100
Status: offline
quote:
ORIGINAL: nitrohog
Ya know, I have been having problems with my OS 32SX-H overheating, do you guys think it is the thermostat or it is a faulty radiator cap? Try asking a young guy at autozombie for a 65 VW Beetle radiator cap some time if you want a laugh.
Heli aye...I think you need a Tuned Immelman Glow Plug from one of the Pattern guys...I heard you can fly inverted with a heli all day long with that plug...Make sure it's the one with the 1/2 roll filament on top...
Hide Signatures
(in reply to nitrohog)
       Post #: 133
RE: Muffler bearings problem, please help!!! - 2/19/2010 6:49 AM
chunkyplunker
Score: 105
Status: offline
quote:
ORIGINAL: LLD
quote:
ORIGINAL: saucerguy
LLD
Hey wait a minute, I've went through chow lines and bearings is not what got cleaned out on me. But hey, I do believe you could substitute the bearings out of a bore evacuator from a M1 Abrahams. They look like the right size.
Club Saito #678
Hide Signatures
(in reply to LD24)
       Post #: 134
RE: Muffler bearings problem, please help!!! - 2/19/2010 7:06 AM
LD24
Score: 100
Status: offline
quote:
ORIGINAL: Arceenut
Sorry if this is a bit off topic, but I seem to have a problem. After several flights today I found my plane extremely sensitive to control. I found on inspection the plane had become rather tail heavy due to an accumulation of propeller pitch all over the tail planes. I tried my usual plane cleaner on it but it wouldn't come off. Does anyone have a good cleaner for this stuff?
I love this forum...I like when I can give back what I have learned...
I had the same problem and a friend at the club had some gyroscopic solution..worked perfectly and my plane balanced right up...This stuff is so good, I cleaned the relative bearings and converted them to true bearings and very stable...My muffler is now perfect...
Hide Signatures
(in reply to Arceenut)
       Post #: 135
RE: Muffler bearings problem, please help!!! - 2/19/2010 7:13 AM
LD24
Score: 100
Status: offline
quote:
ORIGINAL: saucerguy
quote:
ORIGINAL: larryf333
I like going to the restaurant and ordering a grilled cheese sandwich, hold the bread. Heehee
Oooohh, hehe, I can be kind of a stinker in a restaurant. You know when the hostess always asks you how many are in your party, especially when clearly, it's just two people? I've thrown many of them totally off guard when I blurted out 40, lol. They are immediately shocked, lol.
My latest one, we ordered something at Mc Donalds drive through, at the end of the order I told them that it was for here. You'll get some funny reactions with that one as well
I've gone to Burger King and asked for a Big Mac. When they said, "I'm sorry sir, this isn't McDonalds, it's Burger King"...I replied, "So are you saying I can't get it my way"...
Hide Signatures
       Post #: 136
RE: Muffler bearings problem, please help!!! - 2/19/2010 7:20 AM
chunkyplunker
Score: 105
Status: offline
This thread is going to teach me bad habits. Worst I've done is answered the phone "county morgue, you stab em we slab em"
Club Saito #678
Hide Signatures
(in reply to LD24)
       Post #: 137
RE: Muffler bearings problem, please help!!! - 2/19/2010 7:29 AM
LD24
Score: 100
Status: offline
I had a room mate and I answered the phone, "Pizza Hut will this be carry out or delivery?"...Click...They called back and I answered..."Domino's, will this be carry out or delivery?"...Click...
An hour later we get a phone call and my room mate answers...2 seconds later he asked me to never answer the phone again...His mom kept trying to get ahold of him and thought she was dialing the wrong number...
Hide Signatures
(in reply to chunkyplunker)
       Post #: 138
RE: Muffler bearings problem, please help!!! - 2/24/2010 4:30 AM
lbarnes
Score: 100
Last Login: 2/19/2013
Status: offline
Not only can you screw one's head about mechanical things. Next time your at a resturant, with a serious face, ask for diet water.
larry
Never stop flying the airplane until the rudder meets the cockpit
Hide Signatures
(in reply to Bass1)
       Post #: 139
RE: Muffler bearings problem, please help!!! - 10/26/2010 2:03 AM
moe7404
Score: 100
Last Login: 5/13/2012
Status: offline
a friend needed, points, plugs. so he stoped at parts house bought the parts. got in the car , opened the glove box, tossed the parts in, then said "see there runs better all ready" apologizes to the young ones that dont know what points are.
Hide Signatures
(in reply to Bass1)
       Post #: 140
RE: Muffler bearings problem, please help!!! - 11/5/2010 11:12 PM
victorzamora
Score: 134
Last Login: 5/12/2013
Status: offline
If you've ever had a problem with sinusoidal depleneration, reset the dingle arm and then watch this video:
Tact is for people not witty enough to use sarcasm.
Hide Signatures
(in reply to Bass1)
       Post #: 141
RE: Muffler bearings problem, please help!!! - 11/6/2010 6:03 AM
moe7404
Score: 100
Status: offline
the deal is used muffler bearings have to be wraped in flight line then soaked in a bucket of prop wash, for two days. then the bearings will do fine.
Hide Signatures
       Post #: 142
RE: Muffler bearings problem, please help!!! - 11/14/2010 5:07 AM
buchtes
Score: 145
Last Login: 6/16/2013
Status: offline
I usually grease my Muffler Bearings with Salad oil, it last's much longer and tolerates higher operating temps. I have a different problem on my giant scale P-51, the Landing Light in the Wheel Well is leaking Oil,several attempts to fix it failed.
Hide Signatures
(in reply to moe7404)
       Post #: 143
RE: Muffler bearings problem, please help!!! - 8/5/2012 8:49 PM
ehelibuff
Score: 101
Last Login: 6/12/2013
Status: offline
I installed my torrington muffler bearings in backwards once.. It would only allow air to go into the exhaust, not out..
Hide Signatures
(in reply to Bass1)
       Post #: 144
RE: Muffler bearings problem, please help!!! - 8/5/2012 9:25 PM
buchtes
Score: 145
Status: offline
oh boy, that sux.....
Hide Signatures
(in reply to ehelibuff)
       Post #: 145
RE: Muffler bearings problem, please help!!! - 9/14/2012 6:52 PM
Hi-Lift
Score: 100
Last Login: 3/8/2013
Status: offline
I had this problem years ago and found the bearings weren't aligned relative to the pipe axis. You need to check alignment with a simi-digital aneroseter. The aneroseter is also useful for resetting IDs, but that would be another forum topic!
- Hi Lift
Hide Signatures
(in reply to Bass1)
       Post #: 146
RE: Muffler bearings problem, please help!!! - 9/15/2012 2:05 AM
Crazy4Flight
Score: 110
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: saucerguy
simple pre-lube it with midnight oil, the excess will burn off.
it can be found at any Wallmart next to musk oil and mink oil.
Hide Signatures
       Post #: 147
RE: Muffler bearings problem, please help!!! - 9/15/2012 9:12 PM
wcmorrison
Score: 105
Status: offline
What you really need is right hand smoke shifter.  Then you do not have to worry about monkey wrenches or lubing the bearings.  The smoke shifter along with a wooden welding rod will fix it right up for you.
Hide Signatures
(in reply to Bass1)
       Post #: 148
RE: Muffler bearings problem, please help!!! - 9/15/2012 10:13 PM
buchtes
Score: 145
Status: offline
cractus aviation and the supplier are out of product, need to find a new source:
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to wcmorrison)
       Post #: 149
RE: Muffler bearings problem, please help!!! - 9/21/2012 12:15 AM
jayjay283
Score: 110
Last Login: 9/26/2012
Status: offline
After reading all this I went to pep boys and asked for new muffler bearings because my VW makes a rattle at about 3500 rpm, they laughed at me. Then I asked about my AC and they said I needed free on ? It wasnt free, they said put the can in the car. Its sitting there and im no colder
Hide Signatures
(in reply to buchtes)
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
