robg44
Joined: 3/6/2008 From: barbourville, KY, USA Status: offline
heres a list of the parts that the RTR and the PRO dont share. PRO has rtr doesnt. key# prt# 193 9275 ackerman rack im sure some of you will already know these parts are not shared with the two but the newbs like myself didnt. 190 9248 hard anodized alum. front inner susp. mounts (7075 alum.) 183 9253 hard anodized alum. rear susp. mounts. (7075 alum.) 178 9186 alum. wing braces 166 2610 5x8 brake cam bearings instead of bushings 162 9144 top plate 161 9143 5mm shock tower (front) 164 9163 5mm shock tower (rear) 159 9125 chassis 7075 alum. hard anodized and milled for weight reduction. 158 9122 servo tray i thought this was the same also but its different part # 157 9120 servo tray alum. standoffs 156 9102 center diff plate 147 9230 1 pc. engine mount (swk, picco) 142 9196 7075 alum. clutch shoes 132 center cvd's instead of dogbones 126 capped wheel nuts 17mm the only thing that suprized me was the top plate, diff housing plate, radio tray. i did some checking up and there machined. the servo plate is machined so you can mount the servo lower on the chassis. the top plate and diff plate are machined and except flathead screws where the rtr needs button screws. i never really LOOKED at them i guess. i will say again. i know alot of you guys probably already know this stuff but i checked everywhere for this type explanation between the two and all i would get is "shock tower, wheel nuts, thats about it." im glad i did the reasearch and i hope it helps some else out. i may have missed some things so if i did just make me sit in the corner. now heres some option stuff for you newbs like myself with this buggy and maybe some veterens that just hasnt looked. i left out alot of the common stuff, nitride coated parts, springs etc. 9150 alum. rear bulkheads 9140 alum. front bulkheads 9097 alum. center diff housing 9122g carbon fiber servo tray 9154 alum. rear hub carriers 9252 2.25 degree inner susp. mount set 9251 1.5 degree inner susp. mount set 9170 hd hard anodized wheel hub set 9144g carbon fiber top plate 9102g carbon fiber center diff support 9250 hard anodized anti squat shim set 0,1,3 degree 9191 lightened flywheel(hard anodized) i hope this helps someone.
< Message edited by robg44 -- 4/3/2008 12:33:39 AM >
