RE: Turmoil racers
Tower Hobbies
Logged in as Guest
  Printable Version
12 volt 20 amp power supply..Free shipping
Seller:  Faulkner01
Details:   $59.00   |  7/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Turmoil racers
Page: <<   < prev  1 2 3 [4] 5 6 7 8 9   next >   >>
Login
RE: Turmoil racers - 5/6/2008 2:41:46 AM
supertool28
Status: offline
Hi all. Just to update I just ran round 3 of the GA Pro Series. I finished 5th in the a main and am currently 4th in points going in to the finals. Anyone that questions the Turmoil's ability to hang with Losi, Mugen, or what ever. That is your proof. I race Losi's all day and can smoke them. I love this buggy and the V2 .21 is crazy fast. No car that I raced against could out accelerate my car. I just need to drive a little better and I will start to get wins instead of top 5's.
If anyone is interested I will post my set-up in a day or so. Or you can PM me and I will give you my set-up.
(in reply to hpi-rs)
       Post #: 76
RE: Turmoil racers - 5/6/2008 2:57:44 AM
youwish16
Status: online
i'd like to see your setup
right now im running 30wt in the shocks. diffs are 7/5/2. Shocks are layed down as horizontally as possible(like the rc8 setup). Running a picco .21b. 13t clutchbell with avid revolution bearings. havent ran this setup on the track yet. just waiting for round 4 in warner robins , and my transponder
_____________________________
Sportwerks Turmoil w/ Picco .21, Avid Bearings, Dynamite Clutch Shoes & Pipe, Sprektrum Radio, Ace Servos, Team Sidewinder
(in reply to supertool28)
       Post #: 77
RE: Turmoil racers - 5/6/2008 4:48:46 AM
Jamie22
Status: online
Yea post up set up like to check that out. Im running 60 in the front and 40 in the back. Running 5,3,1 in the diffs and shocks still in the stock place. Using a eb mod vspec with a 14 tooth bell
< Message edited by Jamie22 -- 5/6/2008 4:49:27 AM >
Losi 8ightT
Eb Mods Os Vspec
(in reply to youwish16)
       Post #: 78
RE: Turmoil racers - 5/6/2008 4:55:35 AM
pserve
Status: offline
quote:
ok heres a question for all you turmoil racers , what clutch shoes you guys use ?
Mugen white shoes with 1.0 springs here. Going on 3 gal now and they still look OK.
< Message edited by pserve -- 5/6/2008 4:57:52 AM >
(in reply to fatkidjoey)
       Post #: 79
RE: Turmoil racers - 5/6/2008 5:27:39 AM
youwish16
Status: online
those of you that use a starter box, what flywheel do you guys use? i have a ofna universal box that i used for my ntc3 but it wont reach the flywheel on my turmoil
(in reply to pserve)
       Post #: 80
RE: Turmoil racers - 5/6/2008 2:19:10 PM
Jamie22
Status: online
quote:
ORIGINAL: youwish16
Yea I couldnt use the stock wheel. Im using a rd logics box with a fly wheel from a rc8
Losi 8ightT
Eb Mods Os Vspec
       Post #: 81
RE: Turmoil racers - 5/6/2008 9:11:34 PM
westphill24
Status: offline
which one do you have the rtr or the pro? I havent bought a starter box for my pro yet and I want to make sure I get the right one or that the pro's flywheel is a little larger then the rtr.
Revo 2.5, RC18t, f103gt, Recoil
       Post #: 82
RE: Turmoil racers - 5/6/2008 9:41:18 PM
youwish16
Status: online
i have an rtr
(in reply to westphill24)
       Post #: 83
RE: Turmoil racers - 5/6/2008 10:14:20 PM
supertool28
Status: offline
Hi all here is my set-up hope you smoke someone with it.
Front shocks: 30 wt oil, Gray springs no preload
Mounted top: upper center hole
Bottom: outer hole
Caster position: full forward
Rear shocks: 35 wt oil, blue springs 1/4 inch preload
Mounted Top: bottom inside hole
Bottom: outer hole
Diffs: Front 5000, Center 10000, Rear 1000
Front camber: Upper ball Blue spacer, Lower ball Black spacer
Rear camber: 2 degrees positive
Front toe: Positive 2 degrees
Rear toe: positive 3 degrees
Droop Front: set the front screw to just touch the chassis and add 1/4 turn
To set the Rear Droop set your chassis on something that will hold it level and allow your tires to hang. Then set your rear doop to allow the rear tires to hang 1/4 inch lower than the front tires.
BE SURE TO MEASURE DROOP ON A LEVEL SURFACE AND THAT IT IS THE SAME LEFT TO RIGHT.
Rear roll center: bottom center hole
Ackerman: center hole
I drive a high bite track that will blue groove through the day. It is very rough and very tight. As far as jumps it varies from 4inch bumps to a 4 foot jump in the middle of the srtaight that you hit very fast. I run Pro Line Crime Fighters during qualifing and Hole Shots during the Main. My engine is the V2.21 and I use the 7.5mm insert. This insert really makes the engine explode out of the corners with out losing top end. My clutch bell is 13 tooth and I run stock shoes.
       Post #: 84
RE: Turmoil racers - 5/6/2008 10:21:53 PM
matodd_1
Status: offline
I use the Associated factory team starter box (for the NTC3/GT). Works great with the stock flywheel.
Click to see fullsize image.
Click for fullsize
       Post #: 85
RE: Turmoil racers - 5/7/2008 1:56:30 AM
Jamie22
Status: online
quote:
ORIGINAL: supertool28
Bottom: outer hole
Bottom: outer hole
Thanks for the info bro
Losi 8ightT
Eb Mods Os Vspec
       Post #: 86
RE: Turmoil racers - 5/7/2008 2:48:52 AM
hpi-rs
Status: offline
The flywheel is not the problem. its the motor mounts. The rtr uses tall mounts 4 the roto starter, witch wont work. Use the pro mount or sportwerks sells the right mount.
(in reply to Jamie22)
       Post #: 87
RE: Turmoil racers - 5/7/2008 4:57:35 AM
Jamie22
Status: online
quote:
ORIGINAL: hpi-rs
You can use the rtr mount thats what im using
Losi 8ightT
Eb Mods Os Vspec
       Post #: 88
RE: Turmoil racers - 5/8/2008 3:27:05 AM
hpi-rs
Status: offline
4 suppertool- can u explain droop and the purpose of it thanks. thanks
       Post #: 89
RE: Turmoil racers - 5/8/2008 4:39:10 PM
westphill24
Status: offline
What reciever battieries are you guys using? Im finally getting my extra parts for the pro together and I wanted to know which ones to get.
