RE: Turmoil racers
Tower Hobbies
Logged in as Guest
  Printable Version
HIMOTO REDCAT Mamba Eldorada 12MM HEX Wheel Extensions - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Turmoil racers
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: Turmoil racers - 5/12/2008 10:40:09 PM
Jamie22
Status: offline
quote:
ORIGINAL: supertool28
Hi all here is my set-up hope you smoke someone with it.
Front shocks: 30 wt oil, Gray springs no preload
Mounted top: upper center hole
Bottom: outer hole
Caster position: full forward
Rear shocks: 35 wt oil, blue springs 1/4 inch preload
Mounted Top: bottom inside hole
Bottom: outer hole
Diffs: Front 5000, Center 10000, Rear 1000
Front camber: Upper ball Blue spacer, Lower ball Black spacer
Rear camber: 2 degrees positive
Front toe: Positive 2 degrees
Rear toe: positive 3 degrees
Droop Front: set the front screw to just touch the chassis and add 1/4 turn
To set the Rear Droop set your chassis on something that will hold it level and allow your tires to hang. Then set your rear doop to allow the rear tires to hang 1/4 inch lower than the front tires.
BE SURE TO MEASURE DROOP ON A LEVEL SURFACE AND THAT IT IS THE SAME LEFT TO RIGHT.
Rear roll center: bottom center hole
Ackerman: center hole
I drive a high bite track that will blue groove through the day. It is very rough and very tight. As far as jumps it varies from 4inch bumps to a 4 foot jump in the middle of the srtaight that you hit very fast. I run Pro Line Crime Fighters during qualifing and Hole Shots during the Main. My engine is the V2.21 and I use the 7.5mm insert. This insert really makes the engine explode out of the corners with out losing top end. My clutch bell is 13 tooth and I run stock shoes.
Where did you get the spacers from ?
_____________________________
Losi 8ight B
WWW.BADRC.COM
(in reply to supertool28)
       Post #: 101
RE: Turmoil racers - 5/13/2008 12:20:41 AM
supertool28
Status: offline
Congrat's on the good showing. I'm glad that setup worked good for you.
(in reply to tcblr)
       Post #: 102
RE: Turmoil racers - 5/13/2008 12:27:13 AM
supertool28
Status: offline
The spacers for front camber come with the pro buggy. You can also get them form Sportwerks or Horizion hobbies. That goes for the different springs, sway bars and most any other hop up for the Turmoil. Also watch E-bay.
Good luck.
I plan to race round 4 of the Ga pro series. That track is going to be different than what I am used to so Expect another setup to be posted for that track. I will include track conditions.
(in reply to Jamie22)
       Post #: 103
RE: Turmoil racers - 5/13/2008 2:51:44 AM
youwish16
Status: offline
when you go to warner robins, watch out for ruts. it rutted up pretty good during round 2. and watch out for the guy with the washington nationals hat and his blue and white turmoil! Thats me lol
Losi 8ight w/ Picco .21,Avid Bearings,Dynamite Clutch Shoes & Pipe,Sprektrum Radio,Ace Servos,Team Sidewinder,Bad Horsie
       Post #: 104
RE: Turmoil racers - 5/13/2008 4:45:29 AM
Jamie22
Status: offline
Good luck.
Yea I checked ebay and didnt see any so I'll check at the lhs thanks for the info
Losi 8ight B
WWW.BADRC.COM
       Post #: 105
RE: Turmoil racers - 5/15/2008 9:23:40 PM
mthird
Status: offline
Hey,
Has anyone else had a problem with the turnbuckles popping off the Turmoil Pro after a hard landing? My Kyosho has a screw+bolt combo keeping it on but I'm unsure what size is needed.
< Message edited by mthird -- 5/15/2008 9:32:38 PM >
       Post #: 106
RE: Turmoil racers - 5/15/2008 10:21:43 PM
youwish16
Status: offline
yup, happens to me sometimes. just havent gotten around to fixing it yet
(in reply to mthird)
       Post #: 107
RE: Turmoil racers - 5/16/2008 2:55:23 PM
volkankilicoglu
Status: offline
       Post #: 108
RE: Turmoil racers - 5/16/2008 3:37:02 PM
mthird
Status: offline
Nice, V!
Has it been run yet?
(in reply to volkankilicoglu)
       Post #: 109
RE: Turmoil racers - 5/16/2008 3:42:19 PM
Jamie22
Status: offline
Dont look like its ever seen any dirt lol
Losi 8ight B
WWW.BADRC.COM
       Post #: 110
RE: Turmoil racers - 5/16/2008 3:47:22 PM
Jamie22
Status: offline
Heres a pic of mine with the rossi motor on it
Losi 8ight B
WWW.BADRC.COM
       Post #: 111
RE: Turmoil racers - 5/16/2008 4:11:54 PM
hpi-rs
Status: offline
I have some 25% byrons ordered 4 next week. I will try this in my .21 rossi .Do U remove the shim in yours or leave it stock.
       Post #: 112
RE: Turmoil racers - 5/16/2008 4:44:59 PM
Jamie22
Status: offline
quote:
ORIGINAL: hpi-rs
My rossi is stock but i just ran 20% od threw it
Losi 8ight B
WWW.BADRC.COM
(in reply to hpi-rs)
       Post #: 113
RE: Turmoil racers - 5/16/2008 11:33:34 PM
youwish16
Status: offline
all white, thats gonna get dirty quick. i fudged my body, got brake cleaner on it gonna have to get me another.
i also just ran my buggy with a dynamite HT pipe and it has a lot of giddy up. only running at 205-210 right now so when i get the temps up to about 250 it should scream. especially now that i am about to install some nova aluminum adjustable shoes on it
how you guys like my new sticker!!! haha
Click to see fullsize image.
Click for fullsize
< Message edited by youwish16 -- 5/16/2008 11:36:24 PM >
       Post #: 114
RE: Turmoil racers - 5/17/2008 12:19:04 AM
