justinhickey
Joined: 4/25/2008 From: Plano, TX, USA Status: offline
As far as the Sportwerks .21 motor, NO, they have not gotten back to me. Calling is a waste of my time. I tried that and sat there or it was even busy...... Go figure... When you send them an E-mail, you get the standard canned response telling you it can take up to 5 days to get a response.... I send them an E-mail directely and I used thier support website. My next thing to try is a fax. After than, I start e-mailing higher ups in the company. I will get something out of this...I hope! The problem I am also having is with my new Novarossi motor that I got to replace the bad sportwerks unit. It turns much easier after doing some work in, but it too has a snag (no where as bad as the Sportwerks motor). The snag is not too bad, but my OFNA starter box will not sturn the motor. The flywheel just grinds against starter wheel.... I am beginning to think that roto starts are better! At least you can turn those motors..... I will continue working in my new ROSSI motor by hand and hope it gets to a point that the starter box will actually turn the motor. I have been using heat, wd40, and regular after run oil. Like I said, it turns much easier than my DOA Sportwerks motor, but it is still so tight that my starter box will not spin the fly wheel (and not grind down my starter wheel).
_____________________________
Justin Hickey
