Axe CP - Tilts Right on Takeoff
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Axe CP - Tilts Right on Takeoff
Page: [1]
Login
Axe CP - Tilts Right on Takeoff - 3/10/2008 4:42:57 AM
xymox71
Status: offline
Newbie here - As soon as I put enough throttle into the Axe CP she starts tilting to the right...
I tried to trim it out via the transmitter - but it didn't help... And yes I got a little impatient and took it to 75% Throttle thinking I could flight it out.... Big mistake - she still tilted left and I throttled to 0% in time to stop most damage - but I ripped the blades a bit and broke a blade grip.
Any suggestions on what I need to trim to get it to lift off straight up? The Sims (RealFlight) all take off immediately up straight.
       Post #: 1
RE: Axe CP - Tilts Right on Takeoff - 3/10/2008 2:53:57 PM
MMatheny
Status: offline
Normal - the tail rotor pushes right to keep the tail steady, and because it's thrust is below the center of the main blades causes the tilt. Learn to counteract it when you lift off.
_____________________________
Mike
"Never use your shins as a blade tracking device" - Mike
(in reply to xymox71)
       Post #: 2
RE: Axe CP - Tilts Right on Takeoff - 3/13/2008 3:50:42 PM
againstthedevil
Status: offline
I just borrowed a friends axe cp and I noticed the same thing. It seems the heli wants to flip on its right side. I have a theory and as soon as I fix this thing (of course I broke blade grips, woodies, and rear rotor) I'll tell you if it works. I found the tail rotor was slightly tilted, and I don't know if the torque produced from the push of the rotor is enough to effect the flipping tendency of the heli, but I'll try to adjust this and maybe a little more to help minimize the effect. Now I've only flown this thing 3 times so excuse my newbieness.
(in reply to MMatheny)
       Post #: 3
RE: Axe CP - Tilts Right on Takeoff - 3/13/2008 5:32:28 PM
MMatheny
Status: offline
Sorry - I didn't realize the tilt was so drastic! Yes, the tail rotor should be absolutely perpendicular to the main blade!
< Message edited by MMatheny -- 3/13/2008 5:34:57 PM >
Mike
(in reply to againstthedevil)
       Post #: 4
RE: Axe CP - Tilts Right on Takeoff - 5/4/2008 4:01:02 PM
cruzmissile
Status: offline
Yeah having the tail tilted a little can cause it to "swerve" or tilt on take off but also gyro law states that any vertical movement is also going to cause lateral movement. basically, when heli going up, it also goes sideways but soon stablizes.
What goes up must come down, and that is the Landing Gear!
       Post #: 5
RE: Axe CP - Tilts Right on Takeoff - 5/4/2008 7:10:52 PM
Kaptain Chaos
Status: offline
check your servo links had to adjust mine from factory setting to make it level.
(in reply to cruzmissile)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
