HS81 & HS55 Overreacting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HS81 & HS55 Overreacting
Page: [1]
Login
HS81 & HS55 Overreacting - 3/10/2008 5:46:14 AM
BeFlyin
Status: offline
H have a Mplx Easy Glider Electric with HS55's in the ailerons and HS81's for the rudder and elev.
When I use down elev and let go the servo returns slightly past neutral and causes a pitch up attitude, just enough to disturb straight and level flight. Same reaction with the rudder. Both only in one direction. Very annoying.
HiTech receiver, Futaba TX.
       Post #: 1
RE: HS81 & HS55 Overreacting - 3/10/2008 6:51:53 PM
MikeMayberry
Status: offline
This can happen, especially with pushrods that run through sleeves. One way to combat this is to maximize the end point adjustments in your radio and put the linkage on the servo closer in and on the control surface mount it further out. This will allow the servo to travel further increasing the resolution which will help minimize centering issue you are having.
Mike.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to BeFlyin)
       Post #: 2
RE: HS81 & HS55 Overreacting - 3/10/2008 6:56:36 PM
BeFlyin
Status: offline
quote:
ORIGINAL: MikeMayberry
Not sure how to do this but I'll investigate.
Mike.
This I will do. Thanks a heap.
(in reply to MikeMayberry)
       Post #: 3
RE: HS81 & HS55 Overreacting - 3/10/2008 8:50:17 PM
MikeMayberry
Status: offline
Do you have a computer radio?
Mike.
Hitec RCD Rep
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
