This the plugs for my new Q/500
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> This the plugs for my new Q/500
Page: [1]
Login
This the plugs for my new Q/500 - 3/10/2008 4:04:54 PM
Kevin Matney
Status: offline
This the plugs for my new Typhoon Q500
Made of CNC from MDF then sanded and sealed with 3/4oz glass and Skin It Epoxy
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Kevin Matney -- 3/12/2008 2:02:42 AM >
_____________________________
Kevin Matney 2 wrongs don't make a right But 2 Wrights make an Airplane
www.Matneymodels.com
       Post #: 1
RE: This the plugs for my new Q/500 - 3/10/2008 6:40:20 PM
daven
Status: online
Is that going to be conventional tailed?
Looks good.
Dave Norman
klasskote.com
supertrc.com
(in reply to Kevin Matney)
       Post #: 2
RE: This the plugs for my new Q/500 - 3/10/2008 6:51:39 PM
Kevin Matney
Status: offline
No I'm going to make it V Tail. Just a lot easer to layup flat.
(in reply to daven)
       Post #: 3
RE: This the plugs for my new Q/500 - 3/10/2008 7:13:34 PM
daven
Status: online
Yes, it would be a lot easier, at what point do you install the torque rods?
Dave Norman
klasskote.com
supertrc.com
       Post #: 4
RE: This the plugs for my new Q/500 - 3/11/2008 1:40:28 AM
Kevin Matney
Status: offline
After they are cut and glued back together.Then put them in.
(in reply to daven)
       Post #: 5
RE: This the plugs for my new Q/500 - 3/11/2008 1:56:18 PM
Kevin Matney
Status: offline
Ready for paint
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 6
RE: This the plugs for my new Q/500 - 3/11/2008 7:23:16 PM
vertical grimmace
Status: offline
Will this be a new kit?
       Post #: 7
RE: This the plugs for my new Q/500 - 3/12/2008 1:59:55 AM
Kevin Matney
Status: offline
Maybe ??????????????
(in reply to vertical grimmace)
       Post #: 8
RE: This the plugs for my new Q/500 - 3/21/2008 12:33:52 AM
sahartman21
Status: offline
I can't wait.
Are you going to go for 428 or 424 class engines first?
       Post #: 9
RE: This the plugs for my new Q/500 - 3/21/2008 2:10:03 AM
Kevin Matney
Status: offline
It will be ready for both class at the same time.
Typhoon Q500 kit will come 3 ways
1/ Like the Mad Dog kit. Fiber glass with Carbon reinforcement Fuse, Custom Cut Cores and plans an Landing Gear. 424 or 428
2/ Fiber glass with Carbon reinforcement Fuse, vacuum bag wing, and vacuum bag stab an Landing Gear. 424 or 428
3/ Will be a full painted Fiber glass with Carbon reinforcement Fuse, painted wing in mold, And painted in the mold V tail stabs an Landing Gear. 428 only
< Message edited by Kevin Matney -- 3/21/2008 2:25:55 AM >
(in reply to sahartman21)
       Post #: 10
RE: This the plugs for my new Q/500 - 4/15/2008 7:41:55 AM
Kevin Matney
Status: offline
I just painted them black pics to come latter.
       Post #: 11
RE: This the plugs for my new Q/500 - 4/16/2008 9:39:26 PM
Kevin Matney
Status: offline
here they are
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 12
RE: This the plugs for my new Q/500 - 4/16/2008 11:03:09 PM
StanDouglas
Status: offline
Great looking molds Kevin. Wish I had the expertise. I'm still cranking out balsa and foam wing Q500's.
Your V-tail will also have less drag. Especially if the 110 deg angle is at the top of the airframe and doesn't fit in the middle; i.e., on top, forming 3 angles 125/110/125 with the fuse. Verses junctions further down the fuse forming angles of 125/55 and on the other side 55/125.
.| Three angles 125/110/125 (the .| represents the fuse. I had to put the period in to force the formating)
\ / V-tail further down. 125/55/block of wood/55/125. The two 55 degree angles create more drag than the 110.
\|/ V-tail at the bottom, more drag than at the top, 55/55/250 degrees.
And then there's __|__ ugh! Very draggy...
       Post #: 13
RE: This the plugs for my new Q/500 - 4/17/2008 12:32:03 AM
Kevin Matney
Status: offline
Yes the V Stab will be on top of fuse.
(in reply to StanDouglas)
       Post #: 14
