da Rock
NC, USA Status: offline
Yes, Chipmunks are known to be excellent aerobatic airplanes. If you plan to do aerobatics with it, forget about the washout and learn to land it. A buddy of mine has one that's over 2 years old now. He learned to keep the nose down on landing years before and has never had a problem with any of his models. Matter of fact, he doesn't even consider his Chupmunk as anything other than comfortable on landings. He does consider a CAP of his to be a terror. And yet, he's never lost it on landing even once. It has dipped a wing more than once, but since he understands airspeed, keeping the nose down, and not flaring until about to touch down, those dipping wings were just that, dipping wings. Tip stalls are not something that's the result of evil magic. They're the fault of the pilot. They are NOT unavoidable. All you have to do is keep the nose down on landing. And that actually is just the sound byte description for simply keeping the nose from pointing up too much. The airplane just keeps it's nose from pointing up too much. Stalls of any type are from one cause and only one cause. The wing is at TOO GREAT an angle of attack every time it stalls. Period. Every tip stall you ever saw on landing happened when the pilot let the nose get too high. You not only saw the tip stall happen, but you also got a great lesson in what "nose too high" looks like. Unfortunately, most observers don't notice the AOA at all. Keep in mind that almost all the IMAC models are very snappable airplanes. Almost every one of them has significantly tapered wings, and there is little inclination of those guys to washout those wings. And they seldom have problems landing those airplanes. Because they know to keep the nose down on landing, until it's time for the wheels to touch. If all you plan to do is fly around level, put a touch of washout in the wings if you feel more comfortable with it. But even if you don't plan to snap or stunt the sucker, and only bore holes in the sky, keep the nose down on landings and that sucker won't bother you at all. It's fairly easy to land without problems if you learn to do a couple of things. 1. Don't cut to landing speed until you're about to touch down. It's amazing how many people want the airplane almost stopped in the air before it's even to the end of the runway on the way in. 2. Keep the nose close to level until you're almost to touchdown.
