sias2004
Joined: 3/11/2008 From: Bristol, UNITED KINGDOM Status: offline
(Recently acquired stock from closed UK model business) IKARUS, AIRCRAFT: Shock Flyer, Superstar, Extrema, Edge: £12 each (two for £23); Ikarus 3D Power set (brushed motor, g/box, prop): £3; MGM 1210s ESC for brushed motor: £8; IKARUS, HELI: Piccolo FUN, with motor, Kit: £20; Piccolo FUN, with motor, servos, Piccoboard plus. Ready built: £40; Piccolo ECO, with motor, Kit: £42; Piccolo PRO, Kit: £55; Piccolo collective pitch conv kit: £34; Piccoboard PRO: £58; G310 Tuning motor (brushed): £5; Piccolo Night flying kit: £6; TREC TAIL CONTROL FOR HELI: TREC ESC with mix kit: £16; Gain Adjuster: £7; TREC Serial cable: £7; Glitch reducer: £4; Servo rate reducer: £4; PMP HELI PARTS: 1-way kit with tit shaft: £14; Tit shaft alone: £5; CP alumn rotor head: £20; FP alumn swash plate: £23; Main gear 110 teeth: £3; Motor pinions, 8T to 11T: £2.50; CSM GYRO: HLG 200: £40; GWS NARO 4ch Receiver: £7; FUTABA 6-EXA Transmitter (in box): £45; PJS BRUSHLESS MOTORS: 3D-3000 (>3kg thrust): £36; 3D-300SF, 3D-300SFR: £12; 3D-550E, 3D-550R: £15; PJS backplate mount: £2; PJS prop adaptors: £1.50; MODEL MOTORS: Brushless motor, MINI AC 1215/20: £34; HACKER: Brushless motors, B20-15L: £52; B20-36S: £58; C&K MOTOR KITS: 2C-20-310: £12; MAKE YOUR OWN CD-ROM MOTOR: 22mm or 25mm Stators: £2 for 5; Magnets, high quality (Set of 12): £2; Wire (12m length), 0.31mm or 0.40mm: £2; Motor bell, 22m or 25mm: £2 for 5; GWS ORANGE PROPS: 7x6, 8x6, 9x4.7, 9x7, 10x8, 11x4.7: two for £1; 12x6, 13x6.5, 14x7: two for £1.50; GWS BRUSHED MOTORS: Dual IPS, S1,S2,A: £7; EPS 350C: £5; PROP ADAPTORS, (collet type): 3mm shaft, or 4mm shaft: £2; GOLD CONNECTORS good quality: 2mm or 4mm: 4 pairs male/female, £1.50; MGM-COMPRO TMM ESC, FOR AIRCRAFT: (AC-3s; where A=Amps, C=NiCd cell no. to give V, altho these ESC’s use LiPo): 0810-3s: £10; 1210-3s: £10; 1812-3s: £12; 2512-3s: £18; 4016-3s: £26; 6016-3s: £32; 5024-3s: £38; 6032-3s: £54; MGM-COMPRO TMM ESC, FOR HELIS: 1210-3s: £12; 25-12-3s: £20; 4016-3s: £26; MGM COMPRO: LiPoly Battery charger: AQC-04F: £25; KOKAM LIPOLY PACKS: 360 2s1p (20C): £8; 2000 3s1p(20C): £18; 2000 4s1p(20C): £24; 2100 (25C), indiv. cells: £6 each (use to make desired packs); HR-POLY BATT PROTECTOR: Low volt warning, for LiPo, HRPoly-3A, £8; KREIGH MODELS: IFO kit £15; IFO ready built + covered frame (red): £25; TOPMODEL CZ, ARTF AIRCRAFT: Genie (Indoor, 1.1m w/span): £18; Artist (1.6m w/span): £58; Rebelove X-Light (1.6 w/span): £60; Aggressor 240 (2m w/span, F3A aeroplane, all wood, real beauty): £170; FREE AIR, EPP ARTF AIRCRAFT: 2-Cool Biplane (0.9m w/span): £22; Microbat (0.96m w/span): £18; PJS Snake Biplane EPP, ARTF (1.3m w/span, luvly plane): £20; PMP-CZ, EPP, Tucano or Zlin (both 0.9 m w/span): £15; MORRIS HOBBIES: Balsa Nova 40 ARTF (1.6m w/span): £50 ; Balsa Nova 120 Kit (2.1m w/span, with optional clear canopy): £58; Giant Su-Do-Koi Kit (huge plane, 2.3m w/span): £66; JR MODELS: SHARK F3A, 2m Competition F3A plane, Designer: Alex Zapletal; A real beauty, Carbon/Kevlar sandwich fus, 2 piece plug-in foam wings: £360; AERO-WORKS: ARTF: 33% Extra 330L (104” w/spn, 24lb, for 100cc eng): £400; NEWMAN PRECISION MODELS: Loaded Dice 40s kit, 40-size F3A model, superb kit and super flyer, w/span 1.42m, fus 1.5m (Cost £120 in 2001): £40; TEL: UK mob 07838 152 091 EMAIL: sias2004@aol.com
