RE: .o49 engines by cox
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: .o49 engines by cox Page: <<   < prev  1 2 [3]
Login
RE: .o49 engines by cox - 6/25/2008 3:02:13 PM
jessiej
Status: offline
quote:
ORIGINAL: Bugzidor
The prop. is a vintage 'SCAMPER', I guess and I hope, I should have a video clip of this carb. available, soon.
I would recommend saving that prop as a collectable. I fired up an engine with one a couple of years ago and the lovely clear prop shattered after a few seconds of running.
jess
(in reply to Bugzidor)
       Post #: 51
RE: .o49 engines by cox - 6/27/2008 3:41:20 PM
Yuu
Status: offline
I put the AP carb on the SureStart and it stuck out 5/8" beyond the rear of the grey plastic plate. How did you get the carb in there 'so short'? I used the plastic 'tube' the NVA goes in, covered that with a black piece of automotive rubber hose, right over the NVA hole, and plugged the carb into the black rubber. Then I shortened the black rubber until the carb hit the grey plastic tube near where the NVA goes through. No zip ties or hose clamps; just tight rubber hose. But the carb is still 5/8" out behind the engine mount screw holes. I built a test stand to run it. It can be done with a long motor mount stand-off... longer than the SS stand-off for the stock engine. I ran four 3/4 oz. tanks of fuel through it, and it throttles up and down pretty good, IMO. I need to remount it and get some tach readings.
I took it off so I could clean and run an engine for a kid from the 4H group here. Got two of his engines started and he was thrilled. Then I let him fly the CL 'Yellow Peril".... which made 1/2 a lap and the 'landing' busted the right wing into 15 pieces!! But it doesn't count as a "CRASH" because he didn't break the prop! ha ha
       Post #: 52
RE: .o49 engines by cox - 6/30/2008 10:47:12 AM
Bugzidor
Status: offline
I make the carb. body from a small piece of aluminum bar stock, so that, it can fit inside the engine plastic back plate and cut the plastic tube that the NVA goes in then press fit the new carb.(see picture), simple, isn't it? I also link to the carb. testing video clip.
http://www.rcuvideos.com/item/D125TSC8FFZB4YS6/received
Click to see fullsize image.
Click for fullsize
< Message edited by Bugzidor -- 6/30/2008 10:49:49 AM >
(in reply to Yuu)
       Post #: 53
RE: .o49 engines by cox - 6/30/2008 11:15:14 AM
topspeed
Status: offline
Awesome job...I just ordered a used 0.049 from a friend at 12,5 euros ( incl. mail ). There is none in stores here in Finland. I have 2 older 0.049s and one 0.02.
I have also an older Stels 0,049..they are outa business.
Pic below of it.
Click for fullsize
       Post #: 54
RE: .o49 engines by cox - 6/30/2008 5:53:21 PM
jetset1968
Status: offline
quote:
ORIGINAL: Bugzidor
This is my latest version carb. design for SS, which has more compact and relaible throttle responsive.
Any chance you could do a pictorial or video on how you retrofitted that throttle?????
Please !
       Post #: 55
RE: .o49 engines by cox - 7/8/2008 3:38:24 AM
Bugzidor
Status: offline
I'm sorry that, I do not have the pictures, how to retrofit, but, I have a couple drawing. Hopefully that, you could get some idea from them.
Click for fullsize
(in reply to jetset1968)
       Post #: 56
RE: .o49 engines by cox - 7/8/2008 11:42:00 AM
small_rcer
Status: offline
That design is clever!. The needle valve assembly has a venturi or carb throat body in the area of the fuel opening. The whole assembly including the needle valve rotates. Very trick!
I feel that, if Cox had thought of that, all our Cox motors would have been throttled a long time ago.
Congratulations on a very elegant design.
Jim H
       Post #: 57
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.529RCU1
