propjobbill
OH, USA Status: offline
First of all I can't get 18K with a 6x3 prop. I have been using a 6x2 APC prop for those rpm. I'm not sure how much I can get from a 6x3, but I am thinking maybe 15,000. In a few more weeks I will be able to get back to testing if weather permits. The biggest thing that I do is remove the back plate, remove the spray bar, and reed assembly. I chuck up a 3/16 drill bit into the drill press, and drill very slowly from the reed side to the opening where the spray bar goes through. It is very thin and narrows where the spray bar goes through. If you go to fast it will crack the opening. Apply pressure from the needle side of the spray bar when removing the spray bar. If you try from the other direction it will also crack the tube, (I learned this the hard way). I use pliers and caution, I tried pressing the spray bar out. If you apply pressure to the bar without support for the tube it can snap off. After I clean up all the openings from small plastic shavings the drill leaves I reinstall the spray bar. I then carefully open the chock tub in both directions to 3/16”. I use about 30% fuel for high rpm, I also reset the piston. That’s the first thing I do. Drilling out these openings give me between 2,000 |
