new spur gear installation
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> new spur gear installation
Page: [1]
Login
new spur gear installation - 3/12/2008 2:15:24 AM
newpat
Status: offline
Hi,
i know this subject has been dealt with many times and more but i can't find what i think i need...
i stripped my spur gear on Sunday, got a new one tonight... i removed the engine, remove the old spur gear, and am now trying to install the new one exactly how the manual says...
it looks like the washer between the spur gear and the spring is not going all the way down on the shaft so that there is a gap between the spur gear and the washer (the washer does not touch the spur gear)... the spur gear moves back and forth 2-3mm if not more!!!
i know it won't work if i try to run it like this! what's the trick here??? i look at the manual i don't think i'm doing anything wrong... i've got all the parts...
if i tighten the nurt all the way down like crazy, will the washer slide on the shaft? i don't believe so...
any help would be great!
thanks!
_____________________________
Savage X: run it (hard), break it (sometimes), fix it (always), and start again!
       Post #: 1
RE: new spur gear installation - 3/12/2008 2:27:49 AM
SAVAGEBANE
Status: offline
i am new to nitro r/c and i have changed 2 spurs in 3 mo. from the way you describe it i think u should look at ur washer again and if it is like mine then the inside is hexagonal. you might need to useneedlenose pliers to get it on but it should fit right on there. oh yea also there is a silver colored piece that fits real snug into the spur gear itself. make sure it is all the way in.
just curious, y remove the engine. when i did it i just removed the rollbar and the center set of gears which the spur bolts onto. hope this helps.
DONMEGA.
STOCK SAVAGE X 4.6, RUSTLER W/ LRP ESC AND EPIC INTENSE 14 T MOTOR
(in reply to newpat)
       Post #: 2
RE: new spur gear installation - 3/12/2008 3:35:15 AM
newpat
Status: offline
thanks for the answer... the washer goes all the way down the hexagonal part of the shaft... but still, between this point (end of hexagonal part) and where the spur gear sitis, i still have 2-3mm of gap... i can't see how the washer could go any further...
it looks like the spur gear goes too far on the shaft... and by the way, i opened the center set of gears, it's way easier thanks!
(in reply to SAVAGEBANE)
       Post #: 3
RE: new spur gear installation - 3/12/2008 4:12:03 AM
mazdab2600
Status: online
which spur gear setup do you have?
you may have the wrong style for your truck.
the x4.1 or the x 4.6/s25
x4.1 dual slipper pad
x4.6/s25
single slipper pad
f4.6/lrp spec3/piccop3.26 monster/picco p3.28/axial spec1.28
byrons 30%5 trucks.savage strong you bet.
       Post #: 4
RE: new spur gear installation - 3/12/2008 4:50:00 AM
newpat
Status: offline
thanks for the sketches...
i do have the right setup (x4.6 RTR) all the parts are the exact same as the skecth(single slipper pad), it's just that the spur gear seems to float on the shaft!!! no good isn't it? no matter how tight i can tighten the nut, the washer will never go past the hexagonal part of the shaft and thus never apply any pressure on the spur gear...
i really don't trust that assembly until i get a "tighter" solution
thanks for your help though!
(in reply to mazdab2600)
       Post #: 5
RE: new spur gear installation - 3/12/2008 5:21:46 PM
go-to
Status: offline
Dude are you missing the spring that goes on there?!
Savage X SS, FLM LCG TVP, Axial .28, 3-speed, 18/49
Savage 25, SureFire 32R RB Mods, 4-gears diff's, 2-speed, 18/47
       Post #: 6
RE: new spur gear installation - 3/12/2008 5:35:59 PM
newpat
Status: offline
no i've got the spring! when you look at the sketch, the washer goes between the spring and the spur gear, right? i could probably put it the other way (spring first and then washer) and force the spring onto the shaft, but it doesn't seem right!
i'll go to my lhs at lunch break and see what they have to say!
thanks for the suggestion!
(in reply to go-to)
       Post #: 7
RE: new spur gear installation - 3/12/2008 5:39:30 PM
mmduc
Status: offline
pat, did you install a new slipper pad? make sure you install only 1, the washer will only fit all the way on the shaft one way, as it has 2 flat spots on the washer. make sure as per the drawing above that the pin in in the shaft also. if you cant figure it out pm me.
Savage XL K5.9, LST2, Savage x k4.6, Jato 3.3, Ofna ultra gtp w/ picco .27, Baja ss, revo 3.3, raptor 30 v2
       Post #: 8
RE: new spur gear installation - 3/12/2008 7:54:25 PM
newpat
Status: offline
got it figured out...
on my manual the bushing doesn't show (i know, it shows up on the drawing above...shame on me) i'vew got it in now, works perfect until i put it back together
thanks for your help guys!
(in reply to mmduc)
       Post #: 9
RE: new spur gear installation - 3/12/2008 8:08:28 PM
mazdab2600
Status: online
bad hpi.
no pics of the bushing and typo's in the manual.
       Post #: 10
RE: new spur gear installation - 3/12/2008 8:11:35 PM
newpat
Status: offline
yep... i've seen this handwriting annotation on your drawing, i was gonna ask about it and i just forgot... now i know it probably came off with the old spur gear and because it didn't show up, i didn't think i was missing any... well, now i know!
       Post #: 11
RE: new spur gear installation - 3/12/2008 8:27:25 PM
mmduc
Status: offline
bingo all set now. good job!
       Post #: 12
RE: new spur gear installation - 3/12/2008 8:30:52 PM
newpat
Status: offline
i have to learn to pay more attention of what i'm taking out of the truck... if i would have kept the old spur gear safely instead of throwing it in my real truck to go to my lhs (and losing it somewhere in my truck) i would have noticed...
it took me 3 days instead of 3 min to change a spur gear... isn't that what you call a real newb !!!
but btw, i like tearing my truck apart and look at it, it's kinda fun!
(in reply to mmduc)
       Post #: 13
RE: new spur gear installation - 3/12/2008 8:52:03 PM
mmduc
Status: offline
your doin a great job! we were all new once, glad you found it!
       Post #: 14
RE: new spur gear installation - 3/12/2008 8:54:44 PM
mmduc
Status: offline
im new to ebay, im bidding on a new revo! wish me luck..........
(in reply to mmduc)
       Post #: 15
RE: new spur gear installation - 3/12/2008 8:58:11 PM
newpat
Status: offline
i'm new to ebay too... the only parts i bought a week ago are not here yet (stock shocks)
but yeah, good luck!!! i don't think i'd spend $ 300-400 (whatever the revo is) on ebay yet... but i know many guys who do without trouble so go ahead and get yourself one more truck!!!
Have fun!
(in reply to mmduc)
       Post #: 16
RE: new spur gear installation - 5/12/2008 6:35:19 AM
nitro rooky
Status: offline
what is the boil bushing you guys talked about?
