RE: Slow stick Forum!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> RE: Slow stick Forum!!
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Slow stick Forum!! - 3/15/2008 2:08:36 AM
Luv2Flyallday
Status: offline
OK, thanx man. All i want out of this plane is for it to fly slow and long, and fly on thoughs floats. Thats it. Needs to be reliable. Thats why i went with himax. I know i can run twice the max burst amps and it'll still run fine. Just like an AXI. but i still don't know what battery to throw on it..... I need a scale and a watt meter.... lol.
(in reply to tam popo)
       Post #: 26
RE: Slow stick Forum!! - 3/15/2008 2:54:35 AM
tam popo
Status: offline
Luv2 - Hiya!! Cos you will be going off water I reckon a 3S is the way to go, a bit more ooomph for lift off. I would go for a 1700 3S, its just that bit lighter than the 2200Mah and again gives you less weight hence more punch, but you'll still get flight times of 15 minutes. It will also help if you decide to mount a camera later. Hope this helps.....
_____________________________
Born to fly and loose my postings on RCU......
(in reply to Luv2Flyallday)
       Post #: 27
RE: Slow stick Forum!! - 3/15/2008 3:06:59 AM
Luv2Flyallday
Status: offline
Ya man, thanx! I don't want to mount a camera on this slow stick. I want this one to fly slow... so low wingloading. I'm going to get anthor and modify with lots of carbon fiber and a power 10 eflite with a castle creations controller and a 2250 3cell predator.(have all thoughs things lying around!! 15mins is really along time to sit there and fly.... Heck, i fly my u-can-do 3d with a suprass II .70 with the stock tank for only 8 mins with loads of hovering, rolling harriers, etc, and high throttle setting and have 2/3 of a tank left! * mins is awhile to fly for.... i could fly that thing for about 30min with a low low throttle setting i guess. Idk, i don't wana spend all my time on the bench charging... i wana fly when i want, for as long as i want.....(every rc pilots dream right?? )
       Post #: 28
RE: Slow stick Forum!! - 3/15/2008 8:49:47 AM
tam popo
Status: offline
Luv2 - THATS what its all about!!! Leccy flight has that advantage, turn up, turn on and fly on cloud 9, non-polluting (almost!!), and accessible.
Love Cloud 9 - but what happened to clouds 1 to 8???
       Post #: 29
RE: Slow stick Forum!! - 3/15/2008 7:55:55 PM
calvino
Status: offline
got some nice foam tires, and some L shaped plastic to hold my tail on, er, now if only the wind stoped
RC18T 6800 Sidewinder Micro 2s lipo, 1980 Goldpan (needs electronics), ST-1, Slow Stick $15 outrunner combo 3s lipo †
       Post #: 30
RE: Slow stick Forum!! - 3/16/2008 12:25:24 AM
FERNDALE AIR FORCE
Status: offline
Hi all, I took some up to date pics of the SS. Here you go...
Tim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
"...never stop flying the airplane..."
(in reply to calvino)
       Post #: 31
RE: Slow stick Forum!! - 3/16/2008 9:50:50 PM
Luv2Flyallday
Status: offline
Wow man thanks. Ya i am still busy with my other projects so this one gets neglected.(and cause i don't have all the stuff to sit down and make it fly....[motor, battery, 2.4 micro reciever, etc]) Did you guys use some other rods?? mine are to short i think... idk, the manual says for the front of the front wing mount to be 135mm to 140mm back from the front of the fuse. If i put my wing there and hook up the linkage, my servos would hit the wing...
(in reply to FERNDALE AIR FORCE)
       Post #: 32
RE: Slow stick Forum!! - 3/16/2008 10:01:55 PM
FERNDALE AIR FORCE
Status: offline
Good eyes, I'm using the dubro 30" micro pushrod kit.
Tim
       Post #: 33
RE: Slow stick Forum!! - 3/16/2008 10:03:34 PM
Luv2Flyallday
Status: offline
O ya, forgot to tell you guys. This forum should be used to get out some helpful tips on the SS. IDK, like in building, flying, moding, fabing, crashing, you know....lol.
       Post #: 34
RE: Slow stick Forum!! - 3/17/2008 3:42:07 AM
Luv2Flyallday
Status: offline
Thanx. Servo's hitting wing=servo mounts upside down.. woops.
       Post #: 35
RE: Slow stick Forum!! - 3/17/2008 5:08:10 AM
calvino
Status: offline
shoulda fixed da tail on my ss , could have flow it indoors, blah, blah, blah, whatever, do have to find a way to un bend the shaft on my motor , crash into curb, go fig, NOT FAST CRASH , ya, def a fun plane, did get some better landing gear , this stuff has FOAM on it instead of stupid plastic
       Post #: 36
RE: Slow stick Forum!! - 3/17/2008 3:13:11 PM
tam popo
Status: offline
Calvino - what motor is it and what size shaft is it (3mm??). Let us know and we might have an answer for you - do you have an electric drill?
       Post #: 37
RE: Slow stick Forum!! - 3/17/2008 5:37:49 PM
Luv2Flyallday
Status: offline
Hey, anyone think 100 watts of power will lift a 13oz SS with gear or a 1 pound SS with floats?? I think it will. IDK, i want to get that light 2808 himax(1.6oz) instead of the 2812(2.?oz) for 2 reasons. 1.) It's cheaper. 2.) I want to run the BL-12 speed control instead of uping it to a CC Phenix 25. I know you can run it with the BL-12 if you run the right prop but i want to pick a prop that falls under the specs AND is right for me.
       Post #: 38
RE: Slow stick Forum!! - 3/17/2008 8:15:10 PM
ArrowNaughtic
Status: offline
I have been fiddling with my SS a bit and finally have decided to stick with the 1100kv Suppo motor, with a 8 x 6 GWS prop, BP 18A ESC and 2 HS 55's all powered by a CSRC 11.1V 1250mAh lipo. The entire setup takes orders from the AR6000 RX coupled to the DX6. Inverted flights and multiple loops are not uncommon and the only downfall found so far is the wind when over a steady 10mph makes flight very hard to smoothly control.
I also have a GWS Estarter with the same motor but larger ESC and running a APC 9 x 6 prop. I am currently learning on my sim how to roll the Estarter and would really like to know if anyone have been able to roll thier SS. Without ailerons I am sure one could do it, but not sure how to accomplish it. My flight sim doesn't have a SS available (FS One ver. 1.0.9) nor have I heard they will ever offer one.
My personal challange to all SS fliers............... Video of a SS doing rolls without the AIL mod. Just rudder and Elevator. Can it be done??????
_____________________________________________________________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 39
