90SP Muffler failure on run #4.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> 90SP Muffler failure on run #4.
Page: [1]
Login
90SP Muffler failure on run #4. - 3/13/2008 3:54:55 AM
Michael211
Status: offline
As title says, ran the engine on test stand for the 4th time today (w/16 oz tank) and the end of the muffler is already starting to come loose. I could hear a strange noise today while it was running, then after taking it off the stand and looking it over closely I see there is a dark grey paste all around the end of the muffler and once it cooled down I can wiggle the muffler tip around... it's about to pop out.
What is RCV doing to address this problem? I've read of other RCV muffler failures, both in this forum (on a 120SP) and in the Warbirds forum. Mufflers should not come apart!
My engine isn't even broken in yet and the muffler is about to pop apart most likely the next time I run it. In the Warbirds forum a H9 Corsair with a 90SP lost the end if it's muffler in flight and the pilot didn't realize it... exhaust gases ended up burning the crap out of the underside of the plane as a result (without muffler pressure, engine leaned out and got hotter than normal).
My prop (18 x 12 break-in prop) is perfectly balanced on a magnetic Du-Bro high-point balancer to the point where it can be put in any position on the balancer and it will not move. I'm running CoolPower 10% Nitro in the engine and the needle is still quite rich for break-in purposes. As per the observation of others, the engine is still running somewhat rough... though it seems to get smoother and "free'er" with every 16 oz of fuel run thru it.
While I could buy an OS 91 Surpass muffler for my *new* RCV 90SP, I shouldn't have to!
Please advize.
- Michael
       Post #: 1
RE: 90SP Muffler failure on run #4. - 3/13/2008 5:06:43 AM
mboland
Status: offline
If you get in touch with RCV they will most likely send you a new muffler. The replacement ones sent for the 120SP's had 2 screws in the barrel to hold the end piece in.
This fix will work for a WHILE.
Your only option for a permanent fix is get a muffler with the end WELDED in place.
Also, if the oil content is any higher than 15% the engine will always run rough. The 120SP will also detonate which ends up destroying the motor.
_____________________________
It's the quality of life that counts, not the quantity.
(in reply to Michael211)
       Post #: 2
RE: 90SP Muffler failure on run #4. - 3/14/2008 3:06:33 AM
fiery
Status: offline
Michael
Coolpower is not your best choice of fuel for RCV's.
You would be better off with Omega.
RCV recommend that the fuel contain 3% to 6% castor oil, and not more than 16% total oil content.
< Message edited by fiery -- 3/14/2008 4:46:53 AM >
(in reply to mboland)
       Post #: 3
RE: 90SP Muffler failure on run #4. - 3/16/2008 5:29:50 AM
Katman
Status: offline
Mandatory castor is correct as per the instructions, but as a RCV rep now states on this forum Coolpower(synthetic only) is fine for the SP series.
Also, Bill at BJ's(RCV's authorized service ctr) prefers the Coolpower 15% and recommends it for the SP series. He indicated the 15% nitro improves the idle, and synthetic is much cleaner - it won't leave the castor stains all over(as mine did on the muffler), nor the carbon buildup. I burnt about a half-gal of Omega 10% thru my 60SP, and it appears to have loads of "protective" castor varnish now. So my plan is to switch over, since they now say synthetic is ok.
About a mth ago, my 60SP had to be sent in to BJ's for service after problems during run-in. He did several "revisions" apparently RCV still hasn't addressed. Although after several hrs run-in my muffler never came loose, that is one of them he did without my asking. I believe he brazed it in, or something to that effect. They also machined smooth the carb flange, and replaced a fiber washer w/metal lock washer on the carb i'm unable to see. I haven't yet tested it, but they state it now runs like a top(16 x 12 @ 5700rpm) without the stalling or rough-running issues i had. We shall see - hopefully within a couple wks when my plane is done. I'm not sure about revisions to the 90 or 120, but imagine they are similar? Other than my motor coming back with a slightly boogered outer prop lock nut and missing the crankcase vent cover(resulting in some oil coming out in the bag), i would not hesitate to contact him about getting any needed revisions done to them under warranty. Bill is very knowledgeable, helpful, and accessible. All it will cost is the shipping(mine was ~$10).
Hope this helps...
Mark
(in reply to fiery)
       Post #: 4
RE: 90SP Muffler failure on run #4. - 3/17/2008 5:28:15 AM
Michael211
Status: offline
Well I don't have a tach unfortunately, but with Coolpower 10% I can get the idle so low you can actually see the prop as it swings around... and it'll idle like that for several minutes without loading up. Not bad for an engine with only a little over 1 hour's run time on it.
I'm a bit peeved about the muffler coming apart... to be fair, I had read up on these engines quite a bit before deciding to buy one so I was already aware that there've been reported failures of the RCV mufflers. However I'd *hoped* that RCV had addressed the issue and fixed it promptly and that a brand new engine wouldn't come with a poorly built muffler by now.
Brazing or somehow welding the end of the muffler end into the casing is the only way it'll ever hold together... a press fit just isn't sufficient. Why isn't RCV taking care of this defect in their design?
I like the engine so far, I'm annoyed about the muffler though. Would like to see RCV step up to the plate here on this issue.
- Michael
(in reply to Katman)
       Post #: 5
RE: 90SP Muffler failure on run #4. - 3/17/2008 6:08:08 AM
Katman
Status: offline
To give an idea, i purchased mine 12/07 from Hobby Barn reportedly as "new" shipment from the UK. Yet it was manufactured in Jan/Feb 07. I do not know what to make of that, but maybe it's a reflection they do not make many SP series. They may have in fact corrected the muffler issue by now, but there's only one way to find out - ask.
I never owned a tach before getting my RCV, but took the proper break-in of it very seriously and got one for that purpose. It cannot be properly done without one, as specific the procedure is with needle settings etc. For one you can't get an exact reading on your idle needle, as the specific difference needed with glow connected/disconnected is impossible to accurately tell by sound. Bill at BJ's has a great tip sheet for RCV setup, and being very specific regarding rpms and needles doing it minus a tach is not reliable. I'd highly recommend you buy or borrow one.
RCV has excellent service, so contact them and i'm sure they'll solve your problem. But be prepared for a scolding trying to break in their engine properly without a tach...
Good luck to you -
       Post #: 6
RE: 90SP Muffler failure on run #4. - 3/17/2008 5:47:37 PM
Michael211
Status: offline
Katman,
I also run around the house with scissors and I've broken a mirror or two... boy am I ever gonna be in trouble!
Ok so how does one get hold of Bill at BJ's? I'd like to just send the muffler to somebody who can braze (or whatever is needed) the end on solidly. I just want the muffler to be right and not fear it falling apart in flight on my new Mustang.
No problem not having a tach right now, as I'm not running the engine till the muffler is fixed anyways apparently.
Thanks!
ps. How do you find the birth certificate info for these engines? ie. How can I tell when mine was actually built?
- Michael
       Post #: 7
RE: 90SP Muffler failure on run #4. - 3/18/2008 7:35:46 AM
Katman
Status: offline
Obviously unless you want to pay for it, you need to contact RCV first provided yours is new under warranty? If you haven't registered it with them yet now would be the time - it is supposed to be done within 30 days. I'm sure they're glad to send you a new one, but i'd request sending you a "revised" muffler or a return auth # to send the entire motor to Bill(that way any other revisions Bill can do then too).
I do not have Bill's contact info handy, but once you contact RCV they'll give it to you. It is listed all over this forum though. RCV can tell the mfg date from the serial #, it was in correspondence Angela of RCV sent to Bill....
       Post #: 8
RE: 90SP Muffler failure on run #4. - 3/19/2008 12:36:04 AM
Michael211
Status: offline
Ahhh! IC. Yes my engine is already registered with RCV I did it online within days of receiving it earlier this year (late Jan 2008).
I'll figure out how to contact RCV then I guess... they must've stopped monitoring this forum apparently.
Thanks for all the advice Katman. I do appreciate it.
- Michael
       Post #: 9
RE: 90SP Muffler failure on run #4. - 3/20/2008 4:34:15 AM
Katman
Status: offline
Laurenne of RCV was a VERY regular, attentive, and informative visitor to this forum....unfortunately she's gone now.
I'm not sure why they're not getting involved here, lots of the time this tends to happen when they're away attending conventions etc - maybe even here in the states. But they should have someone else tending to customer service if that's the case. Normally they are on any customer's issues immediately. My dealings since i got mine were w/Angela, who was very helpful. The way i contacted RCV w/my problem was i just replied to the warranty registration confirm she sent me....don't have that?
Let us know how it turns out for you -
       Post #: 10
RE: 90SP Muffler failure on run #4. - 3/20/2008 2:23:11 PM
RCV Engines
Status: offline
Hello Michael 211,
We are sorry to hear of the problem with your muffler. We will gladly supply you with a replacement muffler for your RCV90SP. If you could please send your full name and address to sales@rcvengines.com with your engine serial number that will be great.
Many thanks
Stephanie Lawrence
NB. Please note we will be closed for the Easter holidays until Tuesday 25th March.
Technical Support
RCV Engines - UK
       Post #: 11
RE: 90SP Muffler failure on run #4. - 4/2/2008 2:58:22 AM
Michael211
Status: offline
Thank you Stephanie! I was starting to worry if anybody from RCV was around or not... good to see ya'll are still here.
I've been super busy with work the past 2 weeks and haven't had time to deal with this issue further. But I'll get the engine SN and e-mail it to you in just a few minutes here.
I'm annoyed by the muffler problem, but still in awe of this engine ya'll are making!
ps. Yes I have a Hanger 9 optical tach now. However my only 4 runs of the engine have been with the needle valve left in the factory "rich" position so I wasn't trying to adjust the carb... now once I get the muffler problem fixed, guess I'll have to get serious about breaking it in and adjusting it. LOL!
- Michael
(in reply to RCV Engines)
       Post #: 12
RE: 90SP Muffler failure on run #4. - 4/8/2008 6:23:09 PM
Michael211
Status: offline
Hi! I received a new muffler in my mail just yesterday... very fast! Thank you very much!!!
The new muffler appears to have the end MUCH better attached than the original muffler that came with the engine. While apparently still crimped on somehow, the amount of overlap is significantly greater. I'd hope this is the muffler that will be shipping with all future RCV engines!
ps. I ran it briefly with the new muffler yesterday and using the new optical tach I bought from Hanger 9 I was able to read an idling RPM of under 1600 rpms (as low as 1550 rpm with no loading up or dying!), but I'm not able to get over 4500 rpm's on the top end so far. Of course this was just my 5th time to run the engine. Still getting some droplets of fuel coming out the front seal I noticed too, which concerns me a little bit. Tuning engines is not really my strong suite. I'll keep re-reading the instructions and doing test runs till I get the thing set right.
Regards and many thanks!
- Michael
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
