Foxy
Score: 249 Joined: 3/23/2005 Last Login: 11/20/2009 From: Kingston UK, but living in Athens, GREECE Status: offline
Starting? Break-in? Tuning? Temperatures? After run? Starting is easy as 1,2,3. Usually these engines are supplied with the needles in positions which allow the engine to start and idle. If you have trouble on the first start, return the engine to it's factory settings, and try again. To start the engine, first fill the fuel tank. Now close the lid tightly and go to the carburettor on the engine. You'll see a clear squishy 'bulb' on top. Press this until you see it fill up with fuel. Press it a couple more times just to be sure. Now find the choke lever on your engine. Found it? OK, put it DOWN, or if your engine is not upright in the car, move it in whichever direction necessary to CLOSE it. Now pull on the pull starter once, twice, three times. Chances are on the third pull, it either started and stopped, or at least tried to fire. That's good. Now put the choke back up, or reset it to it's default open position, and pull again. Within 2 pulls (more maybe if it's very cold) it should fire up and idle nicely. When the engine is warm, you can quickly start it just by pulling the cord, no need to mess with the choke, that's just for cold starts. Break-in... As I mentioned at the top, no break in 'as such'. To me it's just sensible for the first run not to go crazy while all the screws seat, seals bed in, etc etc. Others say you can full throttle them after only a couple of mins of running. In any case, break in is not something worth frothing over with these cars. Whether you run a full tank or maybe only a half, you can be tuning for performance within about a half hour of the first start. Tuning... These engines have needles similar to nitro engines. There are 3 main adjustments, high speed, low speed and the idle screw. If you have not already done so, reset the engine to factory settings, run it for a tank, then start tuning. Tuning a gas engine is much easier than tuning a nitro engine. They are far more sensitive to needle changes. Start with the low speed, and with the car warmed up and idling, turn it 1/16th of a turn clockwise. You can hear the difference straight away, as the engine speed increases a touch and burbles (bogs) less. You can also hear it start to run lean and speed up a lot if you go too far, what you're aiming for is somewhere in the middle of these 2 sounds. A nice clean idle. You'll get a feel for it quickly. Test the setting by accelerating away from you hard. It should accelerate cleanly and not sound like it's bogging or straining for fuel. Now repeat the process on the other (high speed) needle, but be aware that to test and understand the difference, you should go from a rolling start to full speed, and watch the performance/listen to the engine. There is a very good way of telling how well you have tuned your engine, this is by checking the plug (spark plug). Remove the spark plug from the engine and inspect the tip where the spark is made. If it appears grey and burnt, you are running too lean. If it appears black and sooty, you are running too rich. It should be a nice chocolatey brown colour. Temperatures... These engines have their own cooling fan blades on the flywheel, this pulls air through the pullstart assembly and the engine cowling directs it through the fins of the head, cooling the engine very effectively. There is little need to worry about temperatures with these engines, unless this airway has become blocked. Pullstart outer filters (a cover made of 'breathable' material, usually velcroed around the pullstart assembly), are a very good investment to prevent this airway from getting blocked with grass, leaves and mud. After-run procedure... There is none, leave the fuel in the car as long as you want (within reason, it won't last years!), just remember to shake the tank before priming it for it's next run. The same goes for your fuel can, always give it a shake before fueling the car.
< Message edited by Foxy -- 3/13/2008 2:11 PM >
_____________________________
Nearly all men can stand adversity. If you want to test a man’s character, give him power. - Abraham Lincoln
Hide Signatures
