Eclipse 7 and Elevon Dual Rates ?
Tower Hobbies
Logged in as Guest
  Printable Version
JR XP9303, Spektrum Mod., and Receivers
Seller:  beams
Details:   $475.00   |  6/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Eclipse 7 and Elevon Dual Rates ?
Page: [1]
Login
Eclipse 7 and Elevon Dual Rates ? - 3/13/2008 1:37:05 PM
440GTX
Status: offline
How do you adjust/set the elevon dual rates on an Eclipe 7 ?
The D/R toggle on the elevator and aileron seems to not change the throws.
Thanks in advance.
       Post #: 1
RE: Eclipse 7 and Elevon Dual Rates ? - 3/13/2008 6:13:22 PM
MikeMayberry
Status: offline
Go into the DR setting in the menu and set the travel in each switch position. I typically set 100% for the high rate (switch up) and 65% for the low (switch down.) Then I turn on the flight condition #3 and set everything to 125% for a 3D or "Max" rate.
Again... everything is set in the DR menu and sets the rate according to the switch position or flight condition. The same goes for expo.
Mike.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to 440GTX)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
