RE: Global Hawk UAV - EDF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: Global Hawk UAV - EDF
Page: <<   < prev  1 2 [3]
Login
RE: Global Hawk UAV - EDF - 7/24/2008 9:10 AM
brownlab
Score: 100
Last Login: 1/10/2009
Status: offline
if this plane flies well it might be an interesting micro for me to build.
< Message edited by brownlab -- 8/5/2008 5:32 PM >
_____________________________
the wind is a planes worst enemy
Hide Signatures
(in reply to chrishornby)
       Post #: 51
RE: Global Hawk UAV - EDF - 8/1/2008 12:30 AM
gunracer
Score: 100
Last Login: 12/12/2009
Status: offline
this is a good model...i built one last year and she flys wonderfully...the cg is at the spar so you have to relocate the mains rearward...this will eliminate a lot of the weight up front up to keep the nose down...clean up the ducting and you can fly her on a 3s 2100 pack...hope this helps...
http://www.rcgroups.com/forums/showthread.php?t=734934&highlight=global+hawk
< Message edited by gunracer -- 8/1/2008 12:35 AM >
Hide Signatures
       Post #: 52
RE: Global Hawk UAV - EDF - 8/8/2008 5:18 AM
papajeff
Score: 100
Last Login: 3/14/2013
Status: offline
Gunracer,
Thank you for your comments and for your build information on the Global Hawk. Now that
I have read your build, you are the Master of the Hawk! I hope that I can get mine finished
this season and with your forum as a guide, I think that I can. I'm glad that you posted the
link.
Hide Signatures
(in reply to gunracer)
       Post #: 53
RE: Global Hawk UAV - EDF - 8/8/2008 9:36 AM
astroboycp
Score: 100
Last Login: 8/29/2012
Status: offline
Nice, but wonder if there will be a fibreglass version?
Tam KingTiger|TigerI|Sturmtiger|Sherman|Jadgpanther|Leopard|Pershing|WSNT34|Stuart|Scania|KingHauler|Volvo|Mercedes|Tundra
Hide Signatures
(in reply to papajeff)
       Post #: 54
RE: Global Hawk UAV - EDF - 8/9/2008 1:09 AM
gunracer
Score: 100
Status: offline
anything i can do to help, let me know...just about done with a pusher prop version of this kit...i'll post pixs and a vid at rcg and link it here...
Hide Signatures
(in reply to astroboycp)
       Post #: 55
RE: Global Hawk UAV - EDF - 3/26/2009 7:29 PM
jumper666
Score: 105
Last Login: 4/19/2013
Status: offline
subscribing
Hide Signatures
       Post #: 56
RE: Global Hawk UAV - EDF - 3/31/2009 8:04 PM
wartoy2020
Score: 100
Last Login: 5/24/2013
Status: offline
Ok, I have to have one now. Bad news is sonicelectric are sold out and do not antisipate geting more due to not having a steady market for them.
Ok folks, find dealers that will not charge $150 for an ARF that was sold for $75!!!! "I want my Global Hawk!"
Hide Signatures
(in reply to brownlab)
       Post #: 57
RE: Global Hawk UAV - EDF - 2/5/2013 3:54 AM
Beaufort
Score: 100
Last Login: 2/17/2013
Status: offline
Hi,
Just a quick Query before I glue - are Y connectors used for the tail and the ailerons ?
Which chanels connect to which ?
Do I use mixing ?
Sorry if the answers are self evident but just thought I'd ask now while I can still alter the config.
Many Thanks
Hide Signatures
       Post #: 58
RE: Global Hawk UAV - EDF - 2/8/2013 10:49 PM
Beaufort
Score: 100
Status: offline
From the  Predator Rq-1B thread
< Message edited by papajeff 6/2/2008 8:42 PM >
You are not alone, as the "V" tail configuration is a little confusing. Try this; from the back of the plane,
twist, on the axis, slightly to the right. Now, the top (left "V" tail) becomes the rudder and the right "V"
tail becomes the elevator. Then set up your receiver (I used a Spektrum AR 6100) as follows;
ESC to Throttle position
Aileron servos to Aileron position
Top (left "V" tail) servo to Elevator position
Right "V" tail servo to Rudder position
Depending on your transmitter, (I use a DX-7) you may have a "V" tail setting mode that has to be
enabled. This sure worked for me, so give it a try and let me know if it turned out OK.
Also, there are 4 servos needed; 2 for the ailerons and one for each of the "V" tails.
Is this the same config for the Global Hawk ?
Many Thanks
Hide Signatures
       Post #: 59
RE: Global Hawk UAV - EDF - 2/13/2013 2:31 AM
Beaufort
Score: 100
Status: offline
Connected and glued just hope I guessed right
Hide Signatures
(in reply to Beaufort)
       Post #: 60
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
