Global Hawk UAV - EDF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> Global Hawk UAV - EDF
Page: [1] 2 3   next >   >>
Login
Global Hawk UAV - EDF - 3/13/2008 11:34:46 PM
papajeff
Status: offline
With the popularity of the Nitro Predator RQ-1 UAV, which is a brushless pusher prop, some indepth
searching resulted in an unusual and unexpected find. The Global Hawk UAV, powered by an EDF,
is available at www.sonicelectric.com. Chirs Hornby, the noted RC pilot from the UK, and myself
decided that we just had to get the Global Hawk and start this build. We hope that this project
between the US and UK will be entertaining and informative, as well. So, by jove, let's get this
off to a jolly good start!!!!! Ohhhhhhhhhhhhhhhh............Yeahhhhhhhhhhhhhhhhhhh!!!!!!!!!!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by papajeff -- 3/13/2008 11:46:51 PM >
       Post #: 1
RE: Global Hawk UAV - EDF - 3/13/2008 11:48:35 PM
SON OF PALEFACE
Status: offline
I cant get that link to work , so cant see what your talking about there
Ian
_____________________________
We must have had a BIG earthquake...the ground rose up and HIT my plane , Honest.
(in reply to papajeff)
       Post #: 2
RE: Global Hawk UAV - EDF - 3/14/2008 6:55:50 PM
blfischer
Status: offline
Great. I am only half way through my predator FPV build that I decided to do after I saw your great build up of that... so I will have to plan on getting the Global Hawk now... I can transfer all the electronics over to the global hawk if/when I crash the predator.
Looking forward to it!
I will post pix of my predator on that thread when the avionics come in... seems everything is on back order, but its going to have 900mhz video, co-pilot wing leveler and a Dragon ODS with autopilot return to origin.
Now... how to hide 2 UAVs under the workbench...
(in reply to SON OF PALEFACE)
       Post #: 3
RE: Global Hawk UAV - EDF - 3/16/2008 9:52:49 PM
georgee
Status: offline
Great thread Papajeff,
I"ll keep an eye on this thread,and when finished my other projects, I"ll also put together one G.hawk.
Georgee
I"m tired of airplanes.I just want one more.
       Post #: 4
RE: Global Hawk UAV - EDF - 3/19/2008 7:28:23 PM
papajeff
Status: offline
quote:
ORIGINAL: SON OF PALEFACE
Ian
Try this link again as I know that it is correct; www.sonicelectric.com
       Post #: 5
RE: Global Hawk UAV - EDF - 3/19/2008 7:55:52 PM
SON OF PALEFACE
Status: offline
that worked , thank you , Ian
       Post #: 6
RE: Global Hawk UAV - EDF - 3/20/2008 10:25:31 PM
papajeff
Status: offline
Finally, some photos of the basic Global Hawk EDF. Again, www.sonicelectric.com is the link. I was
surprised to see a minimum of parts; two fuselage halves, the canopy, two main wings, two elevons,
fixed wire landing gear with wheels, wing attachment plate, two fiberglass wing tubes, EDF unit with
cover and a small parts bag. The EPS foam was well done and the grey color was already applied.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by papajeff -- 3/20/2008 10:32:00 PM >
       Post #: 7
RE: Global Hawk UAV - EDF - 3/20/2008 10:36:54 PM
papajeff
Status: offline
The plastic wing attachment segment was well thought out and looks like a great idea.
Click for fullsize
       Post #: 8
RE: Global Hawk UAV - EDF - 3/20/2008 10:41:55 PM
papajeff
Status: offline
The rear "V" tail (elevons) fit into pre-made openings in the rear of the fuselage and it looks like
it will take a little sanding to perfect the fit. The canopy, actually just a foam piece which is part
of the unusual shaped nose, fits nice and snug and will be easy to remove to install the battery
once at the field. In addition, the equipment bay is large enough to house the electronics with
room to spare for battery movement to set the proper CG.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by papajeff -- 3/20/2008 10:49:36 PM >
       Post #: 9
RE: Global Hawk UAV - EDF - 3/20/2008 11:06:58 PM
papajeff
Status: offline
I plan on using the Himax HB2815 inrunner (275 watts...25A...2000kv...40,000RPM) which should produce
about 140W/lb. which is more than enough power for scale like flight. The cradle for the EDF unit has
already been incorporated into the mold of each fuselage half and the attachment parts are two plastic
rails which fit perfectly in place.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by papajeff -- 3/20/2008 11:10:09 PM >
       Post #: 10
RE: Global Hawk UAV - EDF - 3/20/2008 11:20:12 PM
SON OF PALEFACE
Status: offline
good pics Jeff , my only complaint is that the photo's arnt big enough , RCU should be like RC GROUPS with the piccy's BIGGER
       Post #: 11
RE: Global Hawk UAV - EDF - 3/21/2008 2:11:15 AM
papajeff
Status: offline
Ian,
You know, I thought that the RCU Forum photos used to be bigger. Maybe I am not uploading
them correctly. I will check this out and let you know.
       Post #: 12
RE: Global Hawk UAV - EDF - 3/21/2008 2:32:12 AM
papajeff
Status: offline
Chris Hornby, co-contributor of this build from the UK, has stated the following concern about the Global Hawk;
"I was a bit concerned about the fan because the housing tunnel is not clean thru and there would
appear to be plenty of opportunity for turbulence and consequently power loss, but we'll see when
it all goes together." Chris makes a good point regarding his observation of the EDF tunnel. The attached
photos may show this.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 13
RE: Global Hawk UAV - EDF - 3/21/2008 2:41:09 AM
papajeff
Status: offline
Yes, the intake and the exhaust lengths of the actual EDF tunnel are, in fact, very short. Yet, I am
reminded of a Bobcat style airframe that was converted to EDF power and the EDF unit had
no intake or exhaust tubes, at all. It was just attached to the airplane exactly where the pusher
motor had been and the Bobcat flew just fine. Like Chris has said, "We shall see, as our build
progresses."
