newpat
AB, CANADA Status: offline
Hi, I'm a newb too, i got a brand new savage and i can assure you that sometimes it's a pain in the butt to get it started!!! I don't know enough to tell you right away what your problems are, but i went through lots of these forums, picked up some info here and there, and got it running fine... Don't get discouraged (can i say that??) ! once you get it started, running and sliding and jumping all over the place, you'll see that it's well worth the trouble I know that mine starts better if i lean it a bit, and also set the throttle trim a bit high ( i don't know if it's the proper way to do it, but it helps ) it also throws a lot of mud around when the wheels spin in the air !!! Hope you'll figure it out! Good luck, and don't hesitate to ask, there are some great guys who know their stuff around here!!
_____________________________
Savage X: run it (hard), break it (sometimes), fix it (always), and start again!
