mesaflyer
CA, USA Status: offline
Well, I figured out what the F3D former is for. Kinda stupid on my part. They are where the wing pins are going to mount on the fuselage. They way I mounted them is fine. Only I glued them in like the manual said. Wished I would have used epoxy! I am going to take bigtim's advise and strengthen everthing up front with epoxy. For those of you that are following along (if any), I made another bobo on the fuselage when I installed the grooved balse main stringers into the notches in the formers. There is no notch in the last former (F13), and the stringers just butt up against F13. I failed to make sure the stringers were straight. One side is fine, but the other side has a bow down in the end. Made it kinda interesting when it came time to sheet the sides, but I managed. Don't care much for the tail wheel/rear plate/balsa block assembly on the back end. If I had more talent, I would figure out some thing else. But, I have to believe that Top Flight has their reasons for engineering it that way. I am as far as I can go with the fuselage, unless I skip forward, and I don't want to do that. Still waiting for my retracts, so can't do anything else. I have a .46 mustang wing to finish up, so I'll return to this after my retracts are installed. bigtim, I have Futaba 2.4 system. I know it's not fool proof, but it is supposed to not be bothered by RF interference. I did a search on here on that very subject. But I will still take as many precautions as possible. Thanks for the heads up though. Pete rastus21, Sounds like you wil have a couple hundred flights on your Sea Fury before I even get mine painted! Good luck with your build, and keep us posted.
