Widescreen view issue
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Widescreen view issue
Page: [1]
Login
Widescreen view issue - 3/14/2008 5:57:17 AM
SMacafee
Status: offline
I have a 16:10 monitor running 1900x1200, and the plane always flies off the top of the screen. The simulator is set to 1900x1200 @60hz. Is there a fix for this? My monitor can only run the sim in 1900x1200 or in a window. I could run it in a 4x3 window, but that would be a sub-optimal fix.
I just checked and it seems that running it in a window does not help with the plane going off the top of the screen.
< Message edited by SMacafee -- 3/14/2008 6:06:28 AM >
       Post #: 1
RE: Widescreen view issue - 3/14/2008 6:29:39 AM
rajul
Status: offline
Hi smac, what is your windows resolution?
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to SMacafee)
       Post #: 2
RE: Widescreen view issue - 3/14/2008 3:26:06 PM
ChrisAttebery
Status: offline
Are any of the menus off the screen? While you're flying move the mouse and the menu bar should appear at the top of the screen.
I use 1900x1200 (AFP) and have no problems. Maybe the follow mode or zoom settings are messed up. Try backing the zoom down to about 25-30% and see if it happens then.
Good luck,
Chris
ProBro #1959
OMP Edge V3 - Saito 82
(in reply to rajul)
       Post #: 3
RE: Widescreen view issue - 3/15/2008 4:35:54 AM
SMacafee
Status: offline
The height dependent vertical camera was the problem, now I've got it fixed.
(in reply to ChrisAttebery)
       Post #: 4
RE: Widescreen view issue - 3/15/2008 4:40:01 AM
rajul
Status: offline
OK, sounds good.
Mike Marks
RCU Moderator
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
