Patriot XL modifications
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> Patriot XL modifications
Page: [1] 2   next >   >>
Login
Patriot XL modifications - 3/14/2008 8:27:37 PM
tmproff
Status: offline
Well I just bought my first set of Spring Air retracts for a GP Partiot XL that I'm building. I'm an experienced builder, but this is my first attempt at putting retracts on a plane. The retracts were used, but looked in great shape. Just by fiddling with them for about 5 mins, I was able to hook everything up and get them to work properly.
1. Is there any important information that I need to know when installing these?
2. Where is the best place to install the air input nozzle on the plane?
3. Would retract covers make that much of a difference on the performance of the plane?
4. What is the best way to "beef" up the retract area?
Thanks for your help
-Troy
< Message edited by tmproff -- 3/20/2008 8:11:27 PM >
_____________________________
Si hoc legere scis nimium eruditionis habes....
       Post #: 1
RE: Spring Air Advice (Patriot XL) - 3/14/2008 9:27:40 PM
hummingbird111
Status: offline
tmproff..., I recently built the Patriot XL and the 40 size,, the XL was by far alot easy-ier to build ,,, but i used fixed gear, from what i can tell the retracts should be easy to put in and beef up too. I didn't get retracts because they were too expensive for the larger size. Show us some build picks .
--------------VAROOOOM!!!!------------->
(in reply to tmproff)
       Post #: 2
RE: Spring Air Advice (Patriot XL) - 3/14/2008 10:15:51 PM
rmenke
Status: offline
Troy:
I assume you also have the mounting template for the 1/4 ply mounting system. You can use a little thinner ply, but not by much as blind nuts are the best way to go. Have seen some use Sheet metal screws with no problem. To transfer the mount stresses to the wing, you will need to back each of the ribs the mount attatches to. The best way is to build light ply ribs and ca/epoxie them in place. Some triangle stock from the rib to the mount also helps. You want to keep your glue joints and joining surfaces tight as possible.
You want to keep the mount plate as close to the main wing spar as possible in a taildragger configuration. You may have to go with a trike system if you can not get the wheel to miss the main spar. You can bend a small angle in the LG wire to help miss the spar, but not much, th wheel needs to set relatively flat in the wing and be angled correctly for taxiing . Some toe out is ok, just not a bunch. The smaller wheels you use, the easier the install.
Ok, wheel/opening covers (doors) do help with the airflow and drag and also make things look nice. Most newbies will try to produce a cover that works well. They are a mechanical problems in keeping them adttatched to the LG wire as the air pressures on them in flight when coming down are high, and they tend to slip around like a sail. No big deal flying when both do the same thing at the same time, but when one slips into a sail position and the other does not, its almost like trying to fly a twin with one engine out. Its dooable, your chances improve with 3D experience. Also each time you land and bend the gear a little, you have to re-allign the system so it does not hang up. More difficult with a door attached to the LG wire. Yes, ypou can reinforce the wire so it does not bend, but those forces have got to go somewhere. Suggest you leave the door to a future time when you can devote time to building a CF composit door and get some experience with the things under your belt. My first retracts were hand built in the 60's on a bench vice, hack saw, drill press and good files, took around 6 months of R & D, better called trial and error, somehow got all 3 to work off one standard Pro-Line servo. Did wow the guys at pattern contests and cop some wins when points were close. Also embarrassing when your gear falls down on takeoff or landing.
There is some build pics around on the forum that may help. Do a search. ENJOY
       Post #: 3
RE: Spring Air Advice (Patriot XL) - 3/17/2008 8:22:03 PM
tmproff
Status: offline
quote:
ORIGINAL: hummingbird111
Here ya go...I haven't finished sheeting the bottom yet because I still need to run the servo wires for the flaps and ailerons.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by tmproff -- 3/17/2008 8:26:12 PM >
(in reply to rmenke)
       Post #: 4
RE: Spring Air Advice (Patriot XL) - 3/17/2008 9:29:07 PM
airbusdrvr
Status: offline
80 psi is what Bill at Spring Air says should be the pressure to pump the air tank to. Some other brand systems use more psi.
       Post #: 5
RE: Spring Air Advice (Patriot XL) - 3/18/2008 11:18:46 AM
hummingbird111
Status: offline
Very nice work Tmproff , you will love this bird, i have the OS 91 fx on mine and it flys great, i took her out yesterday and buzzed around, flys straight and true , lands exellent also.
(in reply to airbusdrvr)
       Post #: 6
RE: Spring Air Advice (Patriot XL) - 3/18/2008 2:17:17 PM
SitNFly
Status: offline
quote:
ORIGINAL: tmproff
ct area1. Is there any important information that I need to know when installing these?
4. What is the best way to "beef" up the retra?
-Troy
Mine has Robart, but should be similar.
1. Is there any important information that I need to know when installing these? Watch the axle length on the main gear. This is a thin wing and the axle needs to be cut as short as possible to let the mains retract fully. Put a shim on the nose gear to get the nose higher; otherwise you have a tail high stance and the plane doesn't want to rotate.
2. Where is the best place to install the air input nozzle on the plane? I have mine on the side just behind the wing.
3. Would retract covers make that much of a difference on the performance of the plane? I didn't use any but I did wrap some balsa around a spray paint can and used that for wheelwells. Otherwise, the wing is open and bugs and other foof will get into the wing.
4. What is the best way to "beef" up the retract area? I just followed the plans; other than the wheelwells, it went fairly smoothly. The tubing is a tight fit.
You can see mine on the Jett site in the Hall of Fame. It's the black and gold one. It's a fun plane, but is very nose heavy and a bit of a sled. The flaps and retracts are neat, but I don't fly mine much anymore.
       Post #: 7
RE: Spring Air Advice (Patriot XL) - 3/18/2008 2:57:22 PM
tmproff
Status: offline
Well I got a little more done on mine last night. I finished sheeting up the bottom (still need to cut holes for the wire part). Also, I am modifying mine a little by putting both the flaps and ailerons inside the plane to reduce drag. You can see the oval ply pieces beside the retracts I'm going to use for the flaps.
Click for fullsize
(in reply to SitNFly)
       Post #: 8
RE: Spring Air Advice (Patriot XL) - 3/18/2008 4:08:10 PM
phjoker
Status: offline
Looks good sar far. I like the idea of putting the ail and flap servo in the wing.
Looks much cleaner that way.
Revver Bro #157
       Post #: 9
RE: Spring Air Advice (Patriot XL) - 3/20/2008 8:13:33 PM
tmproff
Status: offline
Well, here is the flaps / aileron servos placed into the wing. All screws are recessed so I'm hoping that this little mod didn't add much weight and help with the overall look and drag of the airplane. I should be doing the final sanding and start covering this weekend. More pics to come!
Click for fullsize
Click for fullsize
(in reply to phjoker)
       Post #: 10
RE: Spring Air Advice (Patriot XL) - 3/21/2008 2:39:02 PM
tmproff
Status: offline
Wheel wells have been added. Elevator was glued into place last night and rudder should be going in this afternoon. I'm really liking how this plane is turning out
Click for fullsize
Click for fullsize
       Post #: 11
RE: Patriot XL modifications - 3/21/2008 5:46:55 PM
kamakazie frank
Status: offline
Tmproff:
Great job so far. I like what you did on the inboard servo's for the ailerons and flaps. This is just a suggestion; this kit has a weak rudder setup, I have flutter at high speeds on my XL. I'd test your rudder before sealing up the rear.
Frank
“I have a complex................when I go up everyone comes down.”
AMA #90043....Revver Bro #103
       Post #: 12
RE: Patriot XL modifications - 3/21/2008 5:57:03 PM
tmproff
Status: offline
Did you seal your hingeline? What would you recommend to strengthen the rudder?
I am using some Hitec 645MG's (133 oz torque on 6v) on elevator and rudder and using ball links.
< Message edited by tmproff -- 3/21/2008 7:54:12 PM >
(in reply to kamakazie frank)
