m.gramling
TN, USA Status: offline
I just bought a new TT 46. I put on a Tower hobbies 46 muffler. I can't get the thing the start and run longer than 30 seconds. I have tried opening high end at 2 1/4, 2 1/2, 2 3/4, 3, 3 1/4, 3 1/2, 3 3/4, 4 turns. It will not start at a idle below half throttle. If it does it only run for about 2 seconds then dies. I have to start it at half throttle to full throttle, if it starts, it will only run for about 30 seconds. I have tried 2 differant OS A3 plugs. I am using a new gallon of bryson 15/16 fuel. If I get it started i can run it had full throttle, but as soon as I get it back to half or below, it dies with 3 seconds. I am thinking the low end is way to lean. i know my barrel does shut when I pull the throttle back to idle. It looks like it is around 1/4 throttle. I tried richening up the low end, but my starter batt. went dead. Am I right in thinking my low end is to lean, or do I need to put back on the stock TT muffler and start again.
