RE: Outlaw Build E/Lite
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Outlaw Build E/Lite
Page: <<   < prev  1 [2]
Login
RE: Outlaw Build E/Lite - 4/4/2008 12:50:20 AM
c/f
Status: offline
Props,,,
Well I just got back from Germany and did some prop shopping while over there. WOW is this gonna bring this motor to life.
I found a Cam prop in a 9X6 and 10X8.
The static watts test just completed its looks like a go to me. I forget where I read about using this motor in a speed setup but I'm really liking where it weighs in at and power/batteries for the Outlaw, motor temps with a minute of static running are under 100F. So 2500-3500 sized batteries will be the weakest link in the powerplant loop, just where I like it to be as it is the sweet spot of weight per power battery penalty.
The ARC 36mm will have its work cut out to outperform this setup. Going up to 4000+ MAH battery needs is not actually a better option in my book on this airframe. IMHO
Motor AXI 2826/10
9X6 Graupner CAM
41.2 amps
20.8 VDC
848 watts
10X8 Graupner CAM
58 amps
19.8 VDC
1135 watts
Anyone care to input a known motor calc data for this motor on 6s and these range props? Thanx I dont use or own any motor calc softwares.....
(in reply to c/f)
       Post #: 26
RE: Outlaw Build E/Lite - 6/8/2008 11:54:10 PM
Eric Lis
Status: offline
Here are some pics of my 5S build. Neu1907/1.5y, 5S/3300mah, Hacker Pro 70, 9x9 APC. 14700rpm, and 67amps static. Guessing around 145/150 will have to radar this one.
C/G is right on spot with this setup. Wing has C160 servos I had lying around, and the tail has an 8411. 45 degrees on all control surfaces available.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Eric Lis -- 6/9/2008 12:01:01 AM >
(in reply to c/f)
       Post #: 27
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
