Kyosho Spitfire 90 1/6th scale
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Kyosho Spitfire 90 1/6th scale
Page: [1] 2 3   next >   >>
Login
Kyosho Spitfire 90 1/6th scale - 3/15/2008 5:04:30 PM
Gearhead3
Status: offline
Spitfire 90
Enjoy 90-size big scale flight. Retracts, flaps and detailed camouflage color scheme recreates the famous SPITFIRE spirit.
The legendary WWII fighter credited with the protection of England at the height of the struggle has been recreated as an impressive 90-class model. Elegant elliptical wings and the rounded form has been immaculately reproduced down to the finest detail with retractable undercarriage and split flaps that also replicate the function of the original Spitfire as well as its form. While the large size produces a calm and controlled flight style, the throttle can be opened up to generate the agile stunt flight of a fighter plane. The sporty flying characteristics will suit intermediate to advanced fliers. As the fuselage is mostly pre-assembled with detailed camouflage scheme also complete with printed film, the model exudes quality workmanship all over. Spectacular through the air and as a display, the SPITFIRE 90 recreates the romance and drama of history.
View More Images
Under Side
Split Flap
Features
• Main components are factory assembled so only a short time needed to finish.
• Features lightweight balsa structure. Detailed characteristics of the shape are recreated in the pre-built fuselage.
• Pre-covered in wrinkle-resistant high-quality lightweight camouflage-print film.
• Printed film also replicates the partition lines of the outer planks and hatch in a highly detailed finish.
• FRP cowling complete with coloring.
• Large wing area of the elliptical wing generates the low-speed stability of the original SPITFIRE.
Contents
• 420cc Fuel Tank
• Retractable Landing Gear
• Tail Wheel
• Tires
• Linkage Parts
Required for operation
• R/C System / 7-channel, 8-servo (2 each for ailerons and flaps, 1 for retracts)
• Engine / 2-cycle 90-class, 4-cycle 110-120 class
• Propeller / D15 x P18 - D18 x P6
• 95mm Aluminum Spinner
• Fuel, engine starting tools
• Batteries specified for R/C system
• Glue
Tech data
Length...........56.5"
Wing span.......71.7"
Weight...........9.9lbs (approx.)
Engine............2-cycle 90 class (sold separately) , 4-cycle 110~120 class(sold separately)
Wing Area.......60.28dm2
Wing Load.......79.62g/dm2 (approx.)
Wing Type.......Original Semi-Symmetrical
R/C System......7-channel, 8-servo (sold separately)
Available End of March `08
< Message edited by Gearhead3 -- 3/28/2008 1:25:45 PM >
       Post #: 1
RE: Kyosho Spitfire 90 1/6th scale - 3/15/2008 8:28:39 PM
vasek
Status: online
is this like advertisement?
_____________________________
I am a proud Canadian >living in Europe;-)
(in reply to Gearhead3)
       Post #: 2
RE: Kyosho Spitfire 90 1/6th scale - 3/16/2008 2:42:06 AM
Gearhead3
Status: offline
The nerve of some.......
< Message edited by Gearhead3 -- 3/16/2008 3:19:52 PM >
(in reply to vasek)
       Post #: 3
RE: Kyosho Spitfire 90 1/6th scale - 3/16/2008 3:31:04 AM
Gearhead3
Status: offline
Well, here we go! I just pulled my Kyosho Spitfire 90 out of the box. This is a pretty big airplane.
Click to see fullsize image.
Click for fullsize
       Post #: 4
RE: Kyosho Spitfire 90 1/6th scale - 3/27/2008 9:53:39 PM
perfectplanes
Status: offline
Does any one know what on line dealer is carrying this spitfire?
       Post #: 5
RE: Kyosho Spitfire 90 1/6th scale - 3/27/2008 10:03:07 PM
Gearhead3
Status: offline
try vision hobbies dot com, or roco usa dot com
(in reply to perfectplanes)
       Post #: 6
RE: Kyosho Spitfire 90 1/6th scale - 3/28/2008 3:08:43 AM
NoFlaps
Status: offline
SO HOW'S THE BUILD COMMING ?
HAVE YOU FLOWN IT ?
WHAT PLANE OUT THERE WOULD YOU COMPARE THE arf TO REGARDINMG QUALITY, EASE OF BUILD/ FLYING ETC?
Any landing you can walk away from is a good one.
       Post #: 7
RE: Kyosho Spitfire 90 1/6th scale - 3/28/2008 4:48:28 PM
victorzamora
Status: offline
I had the Kyosho Spitfire 40, and it was gorgeous...a PITA to build, but pretty. It didn't like it when I slammed the throttle, inverting itself on its maiden take-off not even 4 ft off of the ground...and then again about 20ft off the ground. Both times there was a violent snap-roll and the spinner ended up pointing the wrong way. Saved it both times.
It also didn't like low-and-slow w/ no engine. That one I didn't save .
Been looking at getting a Spitfire for my Saito 100. Would that have enough power?
(in reply to NoFlaps)
       Post #: 8
RE: Kyosho Spitfire 90 1/6th scale - 3/28/2008 5:36:24 PM
Gearhead3
Status: offline
victorzamora , you must have done something VERY wrong with that spitfire. I can shut the engine off in flight, and the airplane will glide forever.
NoFlaps, my assembly has come to a halt. I am waiting on a power plant, which has not arrived yet. The Spitfire 90 requires very little gluing, so assembly is quick. The Wing can be taken apart at the center, and the horizontal stabs can be taken taken apart as well. Great for people with small cars, who want to fly a big airplane. I will post up some pictures later of the wing servo installation.
(in reply to victorzamora)
       Post #: 9
RE: Kyosho Spitfire 90 1/6th scale - 3/28/2008 5:52:13 PM
victorzamora
Status: offline
I had it in the closest thing to a harrier a warbird can do . I was also 10ft off the ground, with the tree-line not even 50ft ahead of me...and I had a slight tail wind. I agree, it's all my fault...but it still hurt. Oh, and the CG was a little off .
I hadn't been introduced to 3D yet, but I knew what I wanted to do.
       Post #: 10
RE: Kyosho Spitfire 90 1/6th scale - 3/28/2008 10:10:23 PM
Gearhead3
Status: offline
that would be funny, a spitfire hanging on the prop.......
       Post #: 11
RE: Kyosho Spitfire 90 1/6th scale - 3/29/2008 2:09:53 PM
NoFlaps
Status: offline
Nice to know the wing comes apart...I drive a Mini Cooper
       Post #: 12
RE: Kyosho Spitfire 90 1/6th scale - 4/1/2008 10:40:33 PM
wildswan
Status: offline
I've just these cheap in the UK, apparently the first batch hasn't fuel resistant covering. <g>
       Post #: 13
RE: Kyosho Spitfire 90 1/6th scale - 4/1/2008 10:44:39 PM
victorzamora
Status: offline
if the wings come apart....and it has retracts....how does that work?
(in reply to wildswan)
       Post #: 14
RE: Kyosho Spitfire 90 1/6th scale - 4/1/2008 11:07:23 PM
Gearhead3
Status: offline
The retract servo is in one wing half, not in the center.
