HS-5475HS servo-plug problems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HS-5475HS servo-plug problems Page: [1]
Login
HS-5475HS servo-plug problems - 3/15/2008 9:09:51 PM
freakingfast
Status: offline
Over the last 6 months I’ve purchased eleven Hitec HS-5475HS Digital servos. Of those eleven I found four that the red lead connector was not properly seated in the plug to the point that the little plastic finger engages the connector. This was discovered when I almost crashed my W.M. P-51, I saw one aileron go nuts at run up. Earlier that day it passed the engine running range test. Check those pins and connectors! Other than that, it’s a great servo!
PS
Remember to use only the screw provided for the servo arm, don’t use Loctite, cross thread or start a new lead, and this servo won't let you down.
_____________________________
When in doubt, give it full power. The smaller
pieces fit easier in the bag! Revver Bro #201
       Post #: 1
RE: HS-5475HS servo-plug problems - 3/17/2008 6:40:07 PM
MikeMayberry
Status: offline
I've not heard of an issue like that with any of our servos... if you want to send them in we could check them out. Perhaps you could e-mail me a picture mikem @ hitecrcd.com
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to freakingfast)
       Post #: 2
RE: HS-5475HS servo-plug problems - 3/20/2008 3:38:06 AM
freakingfast
Status: offline
All I had to do is push the wire/connector all the way down, lightly push the little finger in and test tug on the wires, problem solved. All installed and working. Just wanted to give you a heads up so that you could pass it on to your Q.C.
(in reply to MikeMayberry)
       Post #: 3
RE: HS-5475HS servo-plug problems - 3/20/2008 7:14:56 PM
MikeMayberry
Status: offline
Thanks!
Mike.
Hitec RCD Rep
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.324RCU1
