Out of control    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Out of control
Page: [1] 2 3   next >   >>
Login
Out of control - 3/16/2008 4:37 AM
papax5p
Score: 100
Last Login: 3/15/2009
Status: offline
Have the hurricane and the car ran away twice yesterday and ended up breaking the upper and lower arms on the right. Had fresh brand new batteries in it so it wasn't the batteries and the car was only 15 feet away from me each time it started to run away. Went and got the Futaba 3PM 2.4G radio and guess what. The dang thing ran away twice today also. Whats the problem?
Hide Signatures
       Post #: 1
RE: Out of control - 3/16/2008 4:38 AM
5lagd
Score: 100
Last Login: 5/22/2013
Status: offline
crystal not pushed in tight or bad receiver? just my thoughts
_____________________________
Stampede 4x4 & Atomik Barbwire.
Hide Signatures
(in reply to papax5p)
       Post #: 2
RE: Out of control - 3/16/2008 4:44 AM
firebird78
Score: 105
Last Login: 12/8/2011
Status: offline
dang pops...your havin a bad go...cant believe the futuba ran off on ya...must be some sorta radio interferance were ur running..I mean fer 2 diff radio systems to act up somethin ain right....have you tried a diff location?
keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
Hide Signatures
(in reply to 5lagd)
       Post #: 3
RE: Out of control - 3/16/2008 5:15 AM
RedcatRacing
Score: 115
Last Login: 5/20/2013
Status: offline
Are you taping your batteries together in the car? If one battery comes loose you will lose control.
Darin
Darin Oreman
REDCAT RACING / CEO
Hide Signatures
(in reply to firebird78)
       Post #: 4
RE: Out of control - 3/16/2008 5:17 AM
papax5p
Score: 100
Status: offline
Didn't have the problem with the savage today. Ran it for a good 40 minutes and no problem at all. The servo's were going crazy.
Hide Signatures
       Post #: 5
RE: Out of control - 3/16/2008 5:19 AM
firebird78
Score: 105
Status: offline
u runnin hump packs or aa's?.....like Darin said..if ur runnin aa's tape them or wrap a rubber band around em...other then that I have no clue
Hide Signatures
       Post #: 6
RE: Out of control - 3/16/2008 5:22 AM
papax5p
Score: 100
Status: offline
Yes the batteries were all tight into the battery box. I can run my savage out in the same place and no problems at all. Neighbor has a Traxss and no problems. My son had his tornado over here a few weeks ago and he didn't have any problems. I was the only one out here today running and it is out of control. Is it the servo's? I already had to replace the steering servo once. I even had a Condor out here and didn't have any problems.
Hide Signatures
(in reply to RedcatRacing)
       Post #: 7
RE: Out of control - 3/16/2008 5:24 AM
papax5p
Score: 100
Status: offline
Brand spankin new Radio. Futaba 2.4gHz FASST.
Hide Signatures
(in reply to 5lagd)
       Post #: 8
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
its possible that one of the servo's is not good and messing with the reciever
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
       Post #: 9
RE: Out of control - 3/16/2008 5:27 AM
vnmsgt
Score: 101
Last Login: 12/30/2011
Status: offline
If you used two different controllers and one was a 2.4G radio and it ran away it HAS to be in your batteries. They might be tight in the battery box but the connection in the box (soldered wires) itself might be bad. You NEED to tape them to be safe anyways. I was going to say it was your reciever and the antenna maybe came loose from the solder inside teh reciever but it did it on your 2.4G. Has to be your battery box.
Don''t jump on the bandwagon...CRUSH IT
Hide Signatures
       Post #: 10
RE: Out of control - 3/16/2008 5:32 AM
papax5p
Score: 100
Status: offline
I have a hump pack that I just charged today. I'll put it in and see what happens. Just worried that it is going to go crazy and run off again!!
Hide Signatures
       Post #: 11
RE: Out of control - 3/16/2008 5:34 AM
ehroof
Score: 105
Status: offline
are you using the stock servo's?
Hide Signatures
       Post #: 12
RE: Out of control - 3/16/2008 5:39 AM
need2drag
Score: 100
Status: offline
Well have mom stand with the car, and you walk up to the Tuttles driveway, and see if you lose reception on it.
Hide Signatures
(in reply to ehroof)
       Post #: 13
RE: Out of control - 3/16/2008 5:48 AM
Macanan
Score: 100
Last Login: 4/10/2011
Status: offline
quote:
ORIGINAL: papax5p
If all fails check all your wires, because sometimes they screw things on top of them and maybe one is shorting out on the aluminum.
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
       Post #: 14
RE: Out of control - 3/16/2008 5:54 AM
papax5p
Score: 100
Status: offline
Yes they are the stock servo's.
Hide Signatures
       Post #: 15
RE: Out of control - 3/16/2008 5:55 AM
firebird78
Score: 105
Status: offline
u got new servo's with the futaba right??..if so try using them....
Hide Signatures
       Post #: 16
RE: Out of control - 3/16/2008 6:00 AM
twomanytoys
Score: 100
Last Login: 4/23/2009
Status: offline
FAILSAFE!!!!!
The one with the most toys wins. I think I may have a good chance of winning.
Hide Signatures
       Post #: 17
RE: Out of control - 3/16/2008 6:03 AM
need2drag
Score: 100
Status: offline
quote:
ORIGINAL: twomanytoys
FAILSAFE!!!!!
I was waiting for someone to say that. I am personally thinking about a failsafe myself. I haven't had any issues yet, but I really don't want to have any without having a failsafe.
Hide Signatures
(in reply to twomanytoys)
       Post #: 18
RE: Out of control - 3/16/2008 6:05 AM
twomanytoys
Score: 100
Status: offline
I have fail safes in all my rc's and never have had a problem.
Hide Signatures
(in reply to need2drag)
       Post #: 19
ehroof
Score: 105
Status: offline
failsafe and throttle return spring.
Hide Signatures
       Post #: 20
RE: Out of control - 3/16/2008 6:07 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: papax5p
change to new servo's and see what happens
Hide Signatures
       Post #: 21
RE: Out of control - 3/16/2008 6:10 AM
5lagd
Score: 100
Status: offline
i was running my ultrawide yesterday and after about 2-3 minues did a speed run and couldnt stop it, i turned into a snowbank and must have hit it at 30 mph. jumped it and ended in the snow. it was a ful ful ful throttle just whinning. put my finger over the exhaust to stop it. got it back to my car took the body off and said, oh Fluck. forgot to put the screw for the throttle servo horn back on after i had adjused it a few days ago and it popped off jamming the throtle arm at full.lmfao
< Message edited by ldgasp -- 3/16/2008 6:11 AM >
Hide Signatures
       Post #: 22
RE: Out of control - 3/16/2008 6:24 AM
papax5p
Score: 100
Status: offline
I could understand having a failsafe if I was getting out of range. But only 15 feet away and it takes off!! I know we have probably pushed the limit with the savage, neighbors traxss and my sons tornado and haven't had the problem.
Hide Signatures
       Post #: 23
RE: Out of control - 3/16/2008 6:25 AM
codokas
Score: 100
Status: offline
YES SIR!! been there-crashed em- Till I installed Failsafes in them all
DOUG
Hide Signatures
       Post #: 24
need2drag
Score: 100
Status: offline
the failsafe will help with that too.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.016RCU1
