Missileman
MI, USA Status: offline
I have one on every plane I own. Loaded voltmeters are fine and I do own and use one but Voltwatch is a quick check every single flight plus it also verifies your switch and battery connections to your receiver are good, something a loaded voltmeter won't due simply because you are taking readings directly from the battery. This is one, some times heated, topic. You will hear both opinions here.
_____________________________
Comments by author are not to be confused with the truth, past or present.
