RE: Voltwatch, you all use 'em?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> RE: Voltwatch, you all use 'em?
Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: Voltwatch, you all use 'em? - 3/16/2008 7:54:42 PM
balsabuster2003
Status: offline
I have a few on some of my planes. I sometimes use one when setting up end-points for servo travel. If the servo runs into a bind (control surface maxed out), the voltwatch will take a dump, indicating that I need to set a lower end-point.
_____________________________
non impediti ratione cogitationis
(in reply to Campgems)
       Post #: 26
RE: Voltwatch, you all use 'em? - 3/16/2008 8:54:01 PM
RICMOD5634
Status: offline
I Started using them last year and wish I had started long ago , but didn't like the price till I found these. They work just great and some time you can even see the LED on a slow fly by. Check it out 3.97 is a lot better than 10.00.
http://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=2038
Rich
(in reply to balsabuster2003)
       Post #: 27
RE: Voltwatch, you all use 'em? - 3/17/2008 1:15:15 AM
CGRetired
Status: offline
I agree, in part, with what Ken said. Yes, the extended scale voltmeters do a great job of monioring what is going on with the battery. And, when used properly, and at the times when it should be used, it is an invaluable tool. Many do not use an ESV. Why, I don't know. I have one in spite of my use of the Voltwatch. And use it, even though my planes have voltwatch installed. Why? Because there is nothing like a 'second opinion". Hey, if you had a diagnosis of fatal cancer, would you accept it as is or would you search out another doctor to give you a 'second opinion'? I know I would.. thus the ESV and Voltwatch.
Cost is another factor. The brand name "VOLTWATCH" sells for $10.99. I see someone found a 'knockoff' at $3.99. If it works... go for it!! I use this one:
(Tower Hobbies http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHDJ2&P=ML.
And I can fully understand why some may not want to put his in ever one of their planes. Hey, not a problem. I don't have that issue because I don't have that many planes. So, I just install them in each of my new planes and just forget about it. If I had 10 or 15 planes, that means $110 - $160 for a load of voltwatch devices for installation on each plane. That's a lot of loose change for most people. And I totally appreciate that.
My point is simple. The simple fact of the matter is that they are in the circuit and give you a quasi accurate accounting of receiver battery condition. Hey, it's not a "raceable source" calibrated voltmeter. but is 'in the ballpark'. So, it gives you a pretty close estimation of what the battery is doing at any given time, UNDER LOAD. And the load is the current load that the battery "sees".
Don't disregard it as a fad. It is a useful tool and has applications that are well suited for just about every flyer. If you have any questions or any apprehensions about you battery condition, invest your $10.99 (plus shipping and handling.. and get one.
CGr.
< Message edited by CGRetired -- 3/17/2008 11:18:00 AM >
Skylark 70 - OS 75 AX; Venus II - OS 1.20 AX; Tiger 120 - OS 1.20 AX; Protege - OS .75 AX. Airtronics - Spektrum. AMA 705964. Semper Paratus!
       Post #: 28
RE: Voltwatch, you all use 'em? - 3/17/2008 2:52:29 AM
Missileman
Status: offline
There is another way.
I mount my Voltwatch's with velcro, if you can't afford a voltwatch on each model just get a couple and put them on whatever you are taking to the field that day.
Comments by author are not to be confused with the truth, past or present.
(in reply to CGRetired)
       Post #: 29
RE: Voltwatch, you all use 'em? - 3/17/2008 3:57:06 AM
hdwideglide03
Status: offline
There is no reason to not have the voltwatch on your plane IMO. You spent a lot of money and time on your plane. You should put a meter on it to protect it. I find them the most benefincial in the winter time when that cold knocks the heck out the battery. I get five, nine minute flights on each of my planes batteries in the summer time. When winter time is here I get about three nine minute flights. Granted I haven't hit yellow yet but when it shows safe I take it you are safe to put it up or get another battery. As long as the voltwatches are around my planes will have them.
You don''t stop playing because you get old. You get old because you stop playing.
(in reply to Missileman)
       Post #: 30
RE: Voltwatch, you all use 'em? - 3/17/2008 4:35:30 AM
Campgems
Status: offline
quote:
ORIGINAL: balsabuster2003
Great point. I'm about deaf and using a screwdriver as a stecthescope on servos is a rough way to tell when you are stalling them out.
Don
       Post #: 31
RE: Voltwatch, you all use 'em? - 3/17/2008 11:19:52 AM
tlgibson97
Status: offline
I have seen differnt opinions on which way is more reliable so I will ask this question. Has anyone here using a voltwatch or a loaded voltmeter ever gone in because of low battery power? If the users of either have never had an accident because of low voltage wouldn't that make them both equally effective? I have a voltwatch on one plane and don't own a loaded voltmeter. My other 3 planes I just fly with charged batteries. I think as long as you have some way to easily check power levels, loaded or unloaded, it is still better than not having anything at all.
       Post #: 32
RE: Voltwatch, you all use 'em? - 3/17/2008 11:32:55 AM
CGRetired
Status: offline
I have been preaching about the use of voltwatch for quite some time now. Each time it comes up, I usually discuss reasons why. I will reiterate one, and it is just what you brought up. I check my voltwatch before and after each flight. That way, I know going in what the battery voltage is. I am not saying that this cannot be done with an ESV, no quite the contrary. What I am saying is that I check mine before and after each flight, that's all. How an RC'er would do this is totally up to that person. But I highly recommend this practice.
In my case, though, I do have voltwatch on my planes, so it's easy just to glance down, wiggle the transmitter sticks, and watch the reaction on the voltwatch. If it's in the mid green area, and stays in the green with wags of the stick, then I am ok for another flight. If it goes into the red, I recharge.
You can get the same thing from an ESV, by the way. I just prefer the convenience of the voltwatch. And I can see what's going on all the time (on the ground, obviously).
I have a Great Planes Venus II pattery plane. It has an OS 1.20 AX engine, the DX7 radio system, and a pair of 1200 mah NiMH batteries on board. Each battery is plugged into a separate channel port on the RX and each has it's own switch. The way I check the voltage is to operate one switch to on, check the voltwatch (wag the sticks), then turn it off. Then I turn the second one on and do the same thing. If either one shows signs of needing recharge, I recharge both.
I saved my Venus this way one day. I flew three flights, and, after the third flight, I put the plane on the bench in the pits. I checked battery 1, it showed well in the green, with no excursions into the yellow. Good battery. I turned it off and turned the second one on. It was in the red. I cycled it, and it was STILL in the red. So, I grabbed my ESV and checked it that way. It read 1.1 volts, flashed, then went blank. What's going on here? So, I borrowed an ESV from one of the other flyers and checked it again. Same thing. Whoa!!
I removed that battery and put a spare in (Yeah, I keep spare batteries with me when flying), and put both on the charger to equalize them both.
I checked the battery that I took out, and it had a dead cell!!! Two + flights and it was fine. It checked good before the third flight (or I would not have flown) but failed in flight. Probably due to vibration, I don't know, all I know is that it failed.
Saved that plane with voltwatch and ESV.
So, yep, I use voltwatch.
One more quick point. I have also preached, in numerous posts, about the benefits of using the voltwatch for initial assembly of RTF's, ARF's and kit building. You can immediately tell if you have a binding linkage for any control using voltwatch and fix it right then. Binds can also happen after the initial build. If you bump the rudder, or elevator in transit, you could have chipped or broken a tooth on the gears in the servo. This could bind up during operation and you will see that using voltwatch by a jump in the LED's during the stick wagging prior to flight.
CGr.
< Message edited by CGRetired -- 3/17/2008 11:36:37 AM >
(in reply to tlgibson97)
       Post #: 33
RE: Voltwatch, you all use 'em? - 3/17/2008 2:05:04 PM
cruzomatic
Status: offline
All great responses and very interesting points. Voltwatch's are the way to go it seems. I'll pick some up and begin to outfit all my planes with them.
I'm currently building a GP Revolver and the LED's are jumping all over when moving the throttle. An abvious bind that I need to correct.
       Post #: 34
RE: Voltwatch, you all use 'em? - 3/17/2008 2:23:33 PM
CGRetired
Status: offline
There ya go! You found a potential battery drainer there. Good going!!
CGr.
(in reply to cruzomatic)
       Post #: 35
RE: Voltwatch, you all use 'em? - 3/17/2008 2:30:35 PM
hdwideglide03
Status: offline
quote:
ORIGINAL: cruzomatic
The voltwatch is actually doing two jobs like you and CGR said. You check your voltage and can find binds that you may not hear out at the field. My point again. $300+ into a plane what is $9 to make sure you keep it?
< Message edited by hdwideglide03 -- 3/17/2008 2:31:17 PM >
       Post #: 36
RE: Voltwatch, you all use 'em? - 3/17/2008 2:35:48 PM
cruzomatic
Status: offline
I see. So only one LED on at a time? Anything else, then there's a problem??
(in reply to hdwideglide03)
       Post #: 37
RE: Voltwatch, you all use 'em? - 3/17/2008 2:38:22 PM
hdwideglide03
Status: offline
Yes. Of course you see more when you wiggle the sticks but not when they are stationary. If you do then you have a bind somewhere.
       Post #: 38
RE: Voltwatch, you all use 'em? - 3/17/2008 4:30:52 PM
Missileman
Status: offline
quote:
ORIGINAL: hdwideglide03
And what he means is stationary at full throw, great way to check.
< Message edited by Missileman -- 3/17/2008 4:31:05 PM >
       Post #: 39
RE: Voltwatch, you all use 'em? - 3/17/2008 4:50:58 PM
