RE: Voltwatch, you all use 'em?
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld Focke Wulf FW 190 1/4 scale
Seller:  BAGOSTIX
Details:   $5,500.00   |  7/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> RE: Voltwatch, you all use 'em?
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Voltwatch, you all use 'em? - 4/17/2008 7:24:19 PM
bdavison
Status: offline
Heh HEEEh.. Eye like em cause their Shinyeeee
_____________________________
teamflyingcircus.com
(in reply to CGRetired)
       Post #: 126
RE: Voltwatch, you all use 'em? - 4/17/2008 7:26:38 PM
gaRCfield
Status: offline
Nice.
...because flaps are cool.
(in reply to bdavison)
       Post #: 127
RE: Voltwatch, you all use 'em? - 4/23/2008 3:26:39 AM
hungryandbroke
Status: offline
I decided to buy me 1 voltwatch......I'll just put it in one plane and have that plane pull all my others.
Cheaper that way rather than buying one for each plane.
Click to see fullsize image.
Click for fullsize
I learned one thing in this world. It's not how much you make, but how you spend it!
(in reply to gaRCfield)
       Post #: 128
RE: Voltwatch, you all use 'em? - 4/23/2008 11:57:00 AM
CGRetired
Status: offline
Hey.. you may be starting up a trend here. Plane trane... or plain train, or something.
Skylark 70 - OS 75 AX; Venus II - OS 1.20 AX; Tiger 120 - OS 1.20 AX; Protege - OS .75 AX. Airtronics - Spektrum. AMA 705964. Semper Paratus!
(in reply to hungryandbroke)
       Post #: 129
RE: Voltwatch, you all use 'em? - 4/23/2008 12:04:35 PM
kid chuckles
Status: online
How many planes will YOUR Voltwatch pull? I used mine the other day for a doorbell. Then used it after getting doorbell replaced to wash my car. Later that same day and some may not believe this but my grandson rode it to the stoor for a pack of gum. Man they have just so many uses. Let a voltmeter do all that!!!!.
       Post #: 130
RE: Voltwatch, you all use 'em? - 4/23/2008 12:53:43 PM
CGRetired
Status: offline
A doorbell or a doorstop?
(in reply to kid chuckles)
       Post #: 131
RE: Voltwatch, you all use 'em? - 4/23/2008 1:36:08 PM
gaRCfield
Status: offline
I use mine to determine if my rc plan is safe enough for another flight. It does a really good job at that.
       Post #: 132
RE: Voltwatch, you all use 'em? - 4/24/2008 4:52:03 AM
forestroke
Status: offline
lost my cap232 to low rx. i was stupid. it was the only plane that i didn't have a voltwatch on and it went in as i dove for a low pass. dumb and dangerous. if you don't use a voltwatch, make sure you check the voltage EVERYTIME.
be safe.
Member of the 4-stroke Symphony
       Post #: 133
RE: Voltwatch, you all use 'em? - 4/24/2008 1:09:50 PM
kid chuckles
Status: online
Oh man Forestroke that is terrible. We are just poking fun and then to hear that makes me cringe. Hopefully it is repairable. The Voltwatch may not be the best thing for cheking battery power but it does let you know something. I keep my batteries pretty charged up all the time. There have been occasions when i did not charge for a couple weeks and flew fine, but having a Voltwatch just gives you some peace of mind before you take your plane up. I don't own a voltmeter but alot of guys swear by them. Either way it is cheap 10- 11 dollars and looks good too. I don't know price of voltmeter as I probabaly will be stubbern and not buy one but expect they are fairly cheap also lots cheaper than a new airframe. Hate it for you my man.
CG what is that with the DOOR STOP remark? That was DOORBELL DOORBELL,
(in reply to forestroke)
       Post #: 134
RE: Voltwatch, you all use 'em? - 4/24/2008 2:24:57 PM
CGRetired
Status: offline
Well, if it's a small enough door...
One more thing here. The voltwatch is not a loaded device. It relies on the existing load.. RX, servos as the load. So, it cannot be used unless the system is energized.. that is, that the receiver is powered on and supplying power to the servos. Other than that, it is not something that you can just plug into a battery and expect to get a correct reading. It will be high, and not loaded.
For an out-of-circuit test, an ESV must be used, or at least a voltmeter that takes a reading across a load of some sort.
       Post #: 135
RE: Voltwatch, you all use 'em? - 5/17/2008 2:28:46 AM
TheBrickLayer
Status: offline
I got a voltwatch for a gift recently and I have JR equipment. The voltwatch has a tab on the side of the plug that prevents me from plugging it into my reciever. Can I cut that off or should I just send it back?
(in reply to Campgems)
       Post #: 136
RE: Voltwatch, you all use 'em? - 5/17/2008 2:37:35 AM
cruzomatic
Status: offline
Just cut or snap it off. It'll be fine.
(in reply to TheBrickLayer)
       Post #: 137
RE: Voltwatch, you all use 'em? - 5/17/2008 12:15:31 PM
Missileman
Status: offline
quote:
ORIGINAL: TheBrickLayer
You can cut that plastic tab off, it will be fine. Don't forget to set the little switch to the correct voltage if you got the Voltwatch 2.
Comments by author are not to be confused with the truth, past or present.
       Post #: 138
RE: Voltwatch, you all use 'em? - 5/17/2008 12:56:38 PM
panzerd18
Status: offline
I have a JR 4.8v 1100mah Nicad pack, 4.8v 2500mah Nimh pack and a 4.8v 2000mah. I have only used the JR RX pack of 1100mah and have been able to get a full days flying (5 or so flights) no problems. I think if I had a 600mah pack I would be getting worried. So my answer is to get a big capacity RX battery pack and you can insure if you charge the batteries with a peak detection charger the night before you will have no problems.
(in reply to Missileman)
       Post #: 139
RE: Voltwatch, you all use 'em? - 5/17/2008 1:04:12 PM
Missileman
Status: offline
quote:
ORIGINAL: panzerd18
Not always true. Yes high capacity batteries usually mean a full day of flying but a battery pack can fail at any time fully charged or not. Vibration and what not can cause a weld joint in the pack to fail or one of the cells can go bad. You should always check your battery before flying no matter how much the capacity is.
(in reply to panzerd18)
       Post #: 140
RE: Voltwatch, you all use 'em? - 5/17/2008 1:29:40 PM
panzerd18
Status: offline
True but if the battery is going to fail due to vibration then thats the risk I will take. It will probably fail when you are flying and there is nothing you can do once its in the air. On a 4.8 volt system, if one cell fails will it cause a total loss of controls as the voltage to the RX will be too low?
       Post #: 141
RE: Voltwatch, you all use 'em? - 5/17/2008 5:59:34 PM
