MA, USA Status: offline
I don't know much about electric power systems, but there are a couple of .25 size trainer options that you could build and convert to electric. I'm sure someone could advise you on the proper powerplant to use.
Spadtothebone.com has plans for a .25 size BUHOR with a dihedral wing, which is probably the easiest way to go.
I have a downsized Debonair that has .25LA on it. I am planning on maidening it today, and I'll let you know if it's got enough power.
Good luck.
_____________________________
If all of your friends were named Cliff, would you jump off them? - Hugh Neutron
ND, USA Status: offline
You want Fan Fold plans for electric or coroplast? The sky is the limit. Need to know what you really want before anyone can send you down the right path. Any of the smaler spads can be made electric. You just have too buy the right radio and engine gear to support the weight.
-3 cell lipo at 1300 mah. -three channel -emax bl2215/20 -10x6 gws propeller, with motor bl2215/20 develop around 2.65 lb of thrust, can check out if you want. -two towerpro sg90 servo.
Joined: 12/5/2007 From: auckland, NEW ZEALAND Status: offline
that looks great , but i am looking fo something easy to fly as well , SPAD Debonair looks like the one for me would it be posible to make it electric..........if so how????
