Magnum GP40 with 0% nitro fuel. Some question
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Magnum GP40 with 0% nitro fuel. Some question
Page: [1]
Login
Magnum GP40 with 0% nitro fuel. Some question - 3/16/2008 9:17:12 PM
neuroza
Status: offline
Hi!
I have Magnum GP40 engine with air bleed carburetor.
I use my own fuel (20% castor oil, 80% methanol, 0% nitro).
Is it possible that because is without nitro the engine sometimes just die on high RMP (the needle is set very carefully)???
Have another question, when the engine run on minimum,
I turn the nose up and the engine increase in RPM, then when I put the nose down the engine die.
Is this a air bleed problem - did need to be adjusted??? How???
Because I use 0% nitro, do I need to increase compression, how??? Can I put out the thin ring that come under the cylinder head???
Thanks for any help!
< Message edited by neuroza -- 3/16/2008 9:23:02 PM >
       Post #: 1
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/16/2008 9:46:15 PM
jetpack
Status: offline
Not sure about the carb, but taking the head washer out is a good idea. No nitro likes a higher compression and a warmer glow plug.
(in reply to neuroza)
       Post #: 2
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/16/2008 10:05:38 PM
neuroza
Status: offline
Ok, thanks!
I have another question, on some other forum i find that if there is no nitro I can add some acetone... Is that right??? How much???
(in reply to jetpack)
       Post #: 3
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 12:15:18 AM
jetpack
Status: offline
3% if the alcohol your using doesn't already have some in it.
       Post #: 4
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 12:19:41 AM
neuroza
Status: offline
No, I use pure Methanole, and medicinal pure castor oil.
So is this the right mixture???:
20% Castor oil
77% Methanole
3% Acetone
Thanks!!!
< Message edited by neuroza -- 3/17/2008 12:35:44 AM >
       Post #: 5
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 1:03:49 AM
XJet
Status: online
I doubt you'll need (or notice) the effect of the acetone.
I ran a wide range of engines without any nitro for many years back in the 1960s-1980s and they all performed perfectly.
The Magnum GP40 is an engine that should run just fine on 0% nitro. I'd recommend an OS#8 plug -- they seem to work very well with low nitro levels.
_____________________________
When I'm not here, I'm at RCModelReviews
       Post #: 6
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 3:56:03 AM
downunder
Status: offline
It should run just fine on zero nitro but use a hot plug, even a 4 stroke plug. Small amounts of acetone (in that 3% range) is supposed to act somewhat like 5% nitro as far as starting and idling go. It won't hurt the engine so it's just a matter of trying it and see. Taking out the head shim will help a tiny bit by raising the compression slightly but you may get some leakage at the head joint because the shim is also a gasket.
The only thing I can't be sure of is how well an engine runs on zero nitro in cold weather because that's something we don't have here.
(in reply to XJet)
       Post #: 7
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 1:26:36 PM
neuroza
Status: offline
Ok, thanks!
Have another question...
I try to use several synthetic oil but every one drop to the bottom of fuel mixture (the mixture is not homogenic)...
What do I need to pay attention when I buy the right synthetic oil???
(in reply to downunder)
       Post #: 8
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 9:08:56 PM
XJet
Status: online
You can't use a conventional automotive oil (synthetic or otherwise) because, as you've discovered, it won't mix with the methanol.
Your oil choices for a methanol-based fuel are far more limited than for gasoline-based fuels and since the 40GP is a plain-bearing engine it demands a good level of castor oil in the fuel anyway.
I'd try the good old formula of 18%-20% castor oil and 80%-82% methanol.
Synthetic model oils are not well suited to plain-bearing engines but if you're flying in very cold conditions you can use 10% of a suitable synthetic (Motul Micro, Aerosynth, Aerosave, Klotz Techniplate or Morgans CoolPower Blue) and 10% castor. This will make it easier to start your motor -- because straight castor gets real thick at low temps.
Regular automotive oils (synthetic or otherwise) will not mix with methanol -- you need one specifically designed for methanol use.
       Post #: 9
RE: Magnum GP40 with 0% nitro fuel. Some question - 3/17/2008 11:02:03 PM
neuroza
Status: offline
Thanks!
(in reply to XJet)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
