Falkon Ign. & M1 (A123) cells Unregulated
Tower Hobbies
Logged in as Guest
  Printable Version
Saito FA-180 GK
Seller:  RCadmin
Details:   $375.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> ZDZ & RCS Support >> Falkon Ign. & M1 (A123) cells Unregulated
Page: [1]
Login
Falkon Ign. & M1 (A123) cells Unregulated - 3/17/2008 1:47:13 AM
Whymee
Status: offline
I am about to switch 3 ZDZ motors (40, 80 & 160) over to M1 (A123) cells. From what I can gather reading other posts, several people are using the M1 cells (2 cells) on their ignitions, unregulated, with no ill effects. A couple manufactures even said that it was ok to do so.
So I ask the questions...
Is it ok to do so?
If not what is the upper & lower limit of the input of the Falkon ignition?
Thanks in advance...
Blue Skies
       Post #: 1
RE: Falkon Ign. & M1 (A123) cells Unregulated - 3/20/2008 9:48:50 PM
DMichael
Status: offline
Take a look at your ignition box and it should tell you what voltage you can run.
I have Falken ignitions that stipulate 4.8 - 6.0 volts. I don't know if Falken ever made ignitions that would handle more than that but my more recent ignitions are ZDZ branded and will handle up to 9.0 volts. These are not Falken.
If you're not sure then regulate down to 6.0.
Mike would be able to give you a definitive answer but if you go with what it says on the ignition box you'll be safe.
Dave
< Message edited by DMichael -- 3/20/2008 9:54:46 PM >
_____________________________
Team ZDZ
www.rcshowcase.com
(in reply to Whymee)
       Post #: 2
RE: Falkon Ign. & M1 (A123) cells Unregulated - 3/21/2008 1:46:22 AM
Whymee
Status: offline
Thanks!!!
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.485RCU1
