Anyone covered with silver Ultracote?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> Anyone covered with silver Ultracote?
Page: [1]
Login
Anyone covered with silver Ultracote? - 3/17/2008 2:25:53 AM
80stars
Status: offline
Have any of you used silver Ultracote or Mono to cover large surfaces? I am worried it will easily show any imperfections in the surface covered. Also have you had luck using black on large surfaces? My concern is black will absorb to much heat and wrinkle in the sun.
       Post #: 1
RE: Anyone covered with silver Ultracote? - 5/16/2008 10:45:54 PM
Hooked-On-RC
Status: offline
both colours are nasty to work with. Silver is tough cause it shows imperfections under the covering, black shows every tiny little scratch, dent or wrinkle. Unless you have perfect surfaces that you are covering and use a soft cloth all the time to clean up, I would suggest you choose other colors.
_____________________________
Hooked-On-RC
"I am not rich enough to buy cheap stuff"
(in reply to 80stars)
       Post #: 2
RE: Anyone covered with silver Ultracote? - 5/17/2008 2:49:12 PM
capflyr
Status: offline
Black looks great but in the sun it not only wrinkles it we pull back like you hit it to long with A heat gun.Hooked is write stay away from black use it for trim only.
       Post #: 3
RE: Anyone covered with silver Ultracote? - 5/25/2008 9:33:04 PM
80stars
Status: offline
Thanks guys for the tip, I will stick to using it for trim.
(in reply to capflyr)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.312RCU1
