look
Joined: 10/25/2003 From: HaarlemNH, NETHERLANDS Status: offline
Hi, You can order at speed models.nl. First I will build the proto but I know how it flies because I used the airfoils from an earlier design. The root is 9% and the wingtip is 8% both semi. The model will fly on rails, stable and depending on the used engine fast. With an YS 45 it will be a sportmodel, with a Dub Jett FAI a racer. You can use a muffled tuned pipe or an open tuned pipe. An open pipe will give more power. Best regards, Look.
< Message edited by look -- 3/17/2008 7:05:54 PM >
