RE: new design: Strega 45
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: new design: Strega 45
Page: <<   < prev  7 8 9 [10] 11 12 13 14 15 16   next >   >>
Login
RE: new design: Strega 45 - 5/10/2008 10:28:25 AM
look
Status: offline
I am thinking about the next model.
Last week made a start with the Shark with a full cowl but I want to make another very nice speed model.
Has anyone a suggestion or a wish ?
(in reply to look)
       Post #: 226
RE: new design: Strega 45 - 5/10/2008 12:54:28 PM
Rudeboy
Status: offline
Ever thought about a true speed monster...?
Not a "scale" model but something like that Shark, fully cowled engine and pipe, but sized for .60-.90 size engines... Inverted engine setup, high wing, long slender fuse, V-tail perhaps...
_____________________________
Revver Brother #33
...I think it needs more power...
(in reply to look)
       Post #: 227
RE: new design: Strega 45 - 5/10/2008 1:57:26 PM
Strykaas
Status: offline
Yep, a "German speed cup" contestant
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
(in reply to Rudeboy)
       Post #: 228
RE: new design: Strega 45 - 5/10/2008 3:00:01 PM
look
Status: offline
I have thought about that kind of model but for a 40 engine.
I will start with the Shark and that one wll have a full cowl around the engine and pipe.
Do you have a sample how the model must look ?
(in reply to Strykaas)
       Post #: 229
RE: new design: Strega 45 - 5/10/2008 7:34:17 PM
ecoliburger
Status: offline
Look,
I would suggest a 90 sized speed model also. Something designed the OS 91DF, proven engine, very reliable, correct sized tune pipes available. Lots of 40 sized stuff around to go really fast, just look at the q40 or other pylon racers. Nothing currently made for the larger engines.
Hand launch skid landing something just like your Beretta just a lot larger.
Like this would be awesome
(in reply to look)
       Post #: 230
RE: new design: Strega 45 - 5/10/2008 7:42:14 PM
look
Status: offline
Thank you.
And then with a full cowl around the engine and pipe.
Very thin fins and the tail and nose longer. I will think about it.
Thank you very much for the samples.
Are more flyers interested in this kind of models or other models ?
< Message edited by look -- 5/10/2008 8:43:19 PM >
(in reply to ecoliburger)
       Post #: 231
RE: new design: Strega 45 - 5/11/2008 12:08:12 AM
dhal22
Status: offline
i know of a few people who have talked about a speeder designed around the OS 91 VR-DF. something bigger but still very fast.
david
(in reply to look)
       Post #: 232
RE: new design: Strega 45 - 5/11/2008 4:55:48 AM
ecoliburger
Status: offline
If you want to see how much interest you should draw up a rough sketch and start a seperate thread. I know at least 4 or 5 people that would probably buy something 90 sized.
(in reply to dhal22)
       Post #: 233
RE: new design: Strega 45 - 5/11/2008 8:54:19 AM
look
Status: offline
I will start a separate thread about a new model later. Important is to finish the running stuff.
Thanks.
       Post #: 234
RE: new design: Strega 45 - 5/11/2008 8:57:45 AM
look
Status: offline
Back to the Strega. Yesterday morning very early I have made the first fuselage in the new mold.
After some speedflying that day I have made the belly pan. This afternoon I can relieve the fuse out of the mold.
The belly pan tomorrow. Now I can work again on the firewall.
(in reply to look)
       Post #: 235
RE: new design: Strega 45 - 5/11/2008 1:08:41 PM
look
Status: offline
The first fuselage is excellent. I am very glad !!! Batteries were empty so pictures will be later.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by look -- 5/11/2008 1:52:08 PM >
(in reply to look)
       Post #: 236
RE: new design: Strega 45 - 5/11/2008 7:29:18 PM
look
Status: offline
The firewall drawings and CNC cutting files are ready. All fits very well in the cut off nose. Tomorrow I will cnc cut the firewall parts in a good quality 3mm plywood and glue them together to 9mm total. So tomorrow I can build in the engine. Starting with taping the spinner plate to the fuse. Do this carefully and do not forget to mount the small alu Tru Turn insert. And tomorrow I will mark the sample firewall for cutting out the space for the header and pipe. After marking I will update the CNC cutting files.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to look)
       Post #: 237
RE: new design: Strega 45 - 5/11/2008 8:13:04 PM
look
Status: offline
This Hatori 45 tuned pipe will be used on the Strega:
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to look)
       Post #: 238
RE: new design: Strega 45 - 5/11/2008 9:35:24 PM
Strykaas
Status: offline
MMhh looks like the #400 to me, is it ?
ProBro #2077
(in reply to look)
       Post #: 239
RE: new design: Strega 45 - 5/11/2008 9:50:38 PM
