look
Joined: 10/25/2003 From: HaarlemNH, NETHERLANDS Status: offline
Strykaas, you are right. But you are an artist !! Thanks for the drawing !! It looks very good. Or two strips of plywood (one on each side) with a blind nut and a small bolt. Regards, Look The stab has been glued in the fuse and filler has been applied. Tomorrow I can send the filler and start with the thin glasscloth on the stab and wing. The stab has been glued on the outside wit ZAP green and on the inside with UHU plus.
