look
Joined: 10/25/2003 From: HaarlemNH, NETHERLANDS Status: offline
Thank you. You can build models like me, it is very simple but you will have to follow this thread and build your model this way. Try it and you will like it !! All balsa, epoxy plate and plywood cnc parts are in the kit. Our speedmodels we build to fly on our local field are very strong. After three years all parts have to replaced like engine bearings and servo's but the models are still flying fast and are still strong. At the moment I am not sure how to connect the servo to the elevators. I am thinking to put two servo's in the tail with a direct connection to the elevator. This must be ready before I can start painting. The rudder will be closed loop with thin iron cable in a tube. So the elvator is at the moment a problemm. The belly pan mounting is ready and cnc cut. I will show that. Some parts are glued at the moment.
< Message edited by look -- 6/18/2008 8:34:41 PM >
