RE: new design: Strega 45
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: new design: Strega 45
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: new design: Strega 45 - 3/24/2008 2:37:37 PM
look
Status: offline
You can order an OPS with me. With open pipe or muffled tuned pipe.
They are back in production on request.
< Message edited by look -- 3/24/2008 2:39:03 PM >
(in reply to izzy)
       Post #: 51
RE: new design: Strega 45 - 3/24/2008 2:56:48 PM
look
Status: offline
Mold parts painted. Soon I can start with the last part of molding.
The paint has to dry for 24 hours and the plug has to be waxed five times.
Now I can start building the wing and stab and making the building instructions with pictures.
Click to see fullsize image.
Click for fullsize
(in reply to look)
       Post #: 52
RE: new design: Strega 45 - 3/24/2008 3:45:12 PM
look
Status: offline
The belly pan mold has been waxed 5 times and put in a gelcoat.
Tomorrow I will make the first belly pan.
I have started glueing the leading edges and waxing the fuse plug.
(in reply to look)
       Post #: 53
RE: new design: Strega 45 - 3/24/2008 4:58:31 PM
look
Status: offline
Glueing the leading edge with Elmers white, shaping with a razorblade tool, sanding with a block in the airfoil contour and final fine sanding with a piece of sandpaper 150 gritt pulling on the ends and make the LE with a nice rounding following the airfoil.
Do not make the LE sharp.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by look -- 3/24/2008 8:15:39 PM >
(in reply to look)
       Post #: 54
RE: new design: Strega 45 - 3/24/2008 5:01:01 PM
look
Status: offline
Now I will have to make the routing files for the wing and stab tips und cut the tips.
The middle part of the wingtip is thin plywood and on both sides it is balsa.
More tomorrow.
(in reply to look)
       Post #: 55
RE: new design: Strega 45 - 3/24/2008 9:06:41 PM
izzy
Status: offline
look
can you tell us how the wing will be supplied
will it be sheeted with leading edge and tip already glued?
what will be left to do ?
how much is the ops 60 with pipe etc , and does anyone know how it compares to the Jett 60L FIRE engine
(in reply to look)
       Post #: 56
RE: new design: Strega 45 - 3/24/2008 9:55:07 PM
look
Status: offline
Izzy,
I will make a deluxe kit with glued, shaped and sanded leading edge and tips and a basic kit where you can do this yourself.
You will have to glue the wing together, glue in the wingspar, glue in the servo plate. Glue in the firewall, stab and servomount.
The plywood for the wingbolts have to be glued and the bolts for the bellypan has to be mounted. Ailerons are complete ready for use. Glue the cnc controlhorns in the ailerons and elevator. All parts are cnc cut. Price of an OPS can I tell you later.
Difference between Jett and OPS can I not tell you. The wingspar, servo's, ailerons and retracts are cnc cut out of the wing.
Regards,
Look.
(in reply to izzy)
       Post #: 57
RE: new design: Strega 45 - 3/24/2008 10:48:19 PM
MJD
Status: offline
quote:
ORIGINAL: look
Any idea of the cost? This is the 5 port, rear intake, rear exhaust engine, right?
(in reply to look)
       Post #: 58
RE: new design: Strega 45 - 3/25/2008 9:07:31 AM
YUKONFLYR
Status: offline
quote:
ORIGINAL: look
Same here! Would like to know the cost and availibility
_____________________________
My Speed Demon made me do it!!! <Possessed since 1968>
Revver Bro 178
(in reply to look)
       Post #: 59
RE: new design: Strega 45 - 3/25/2008 11:31:02 AM
look
Status: offline
The LE glued to the wings:
Click for fullsize
(in reply to YUKONFLYR)
       Post #: 60
RE: new design: Strega 45 - 3/25/2008 11:32:17 AM
look
Status: offline
The first mold has been used to make a belly pan from glass and carbon roovings:
Click for fullsize
Click for fullsize
(in reply to look)
       Post #: 61
RE: new design: Strega 45 - 3/25/2008 11:57:09 AM
look
Status: offline
Here are some prices from OPS.
The engines are in production and we are waiting for a delivery.
57851040 SPA RCA + 574920 175,00 40FIRE with pipe open
57856040 SLP RCA 165,00 40 engine front intake
57857040 SLP RCB 175,00 40 engine
57858040 SLP Pylon 165,00 40 pylon engine and pipe
57867040 SPP RCB + 574920 195,00 40 RIRE pipe open
57868040 SPP Pyl. + 574920 195,00 40 pylon engine + reso open
57869040 SPP VAE + pipa 165,00 40 speedengine with pipe open
10ccm SPP VAE RC 280,00 60 speedengine with carb. and pipe
SPP means rear intake and rear exhaust
VAE means speed engine
574920 is tuned pipe open
prices in Euro without shipping costs.
< Message edited by look -- 3/25/2008 12:49:39 PM >
(in reply to look)
       Post #: 62
RE: new design: Strega 45 - 3/25/2008 12:02:01 PM
HaveBlue
Status: offline
thanks for posting those engine prices, I too have been following this thread with great interest, the strega looks fantastic, very nice job indeed.. i think one of those OPS speed engines is a "must have" item..
if your still in control....you aint goin fast enough
**Revver Bro 95**
(in reply to look)
       Post #: 63
RE: new design: Strega 45 - 3/25/2008 12:51:40 PM
look
Status: offline
Thank you ! I am glad you like this thread.
Later I will cut the wing and stab tips with the router.
Look.
< Message edited by look -- 3/25/2008 12:53:22 PM >
(in reply to HaveBlue)
       Post #: 64
