dick Hanson
quote:
ORIGINAL: Paul Cataldo Yes, I agree, I would NOT even consider using an analog trim to kill my engine. Screw that. I'm disliking the JR more and more. You have to actually use a MIX to design a thr kill? Good Lord. Well, anyhow, just to be fair, I just checked Cheif A/C's site, and looked at the 2.4 9303. It looks like I can have ONLY up to 9 channels with this radio. Can anyone tell me WHICH Rx I will want to buy with the JR 9303?? I see Chief is offering it with the "R921 DSM2" Rx, and I'm a bit confused about a couple of things. 1. What is the deal with the "AR9000" or "AR9100" ? Rx's I keep seeing people mention, and how do they differ from the "R921 DSM2" Rx that comes with the 9303 at Cheif??? 2. I read about the "R922 DSM2" Rx from JR, and it says it has a "soft switch that fails in the on position". What is the deal with this "soft switch"??? Does this actually take the place of dual, redundant switches that I've always used with my Giant Scale 72mhz planes???? I mean, IF I switch to 2.4ghz, will I still need to run TWO redundant switches with this new 2.4ghz setup or what??? I'm still trying to figure out a few things about 2.4 guys, so bear with me. I'm doing all the reading I have the time for... BTW, why on God's green Earth would JR give people OVERSEAS a digital trim, but give us the shaft of an analog trim???? I'm trying to make sense of that.... well --- actually we far prefer the analog trim - It is a thing which typically is a result of a fair amount of experience and the ease in setting low speed throttle as required .
_____________________________
I am watching you Libby
