fallingleaf
Joined: 4/14/2008 From: Auckland, NEW ZEALAND Status: offline
Nick, yeah i think is probably is a little excessive in hindsight, the plane isn't as big as I thought it was! However, I know another in y build thread has used the 120ax and built the plane stock and has had a great few flights with it thus far. I have reinforced the wing joints with 4" wide fiberglass and much thicker wing strut tabs, larger nylon wing bolts (1 in front, two at the rear for the bottom wing), flying wires for rigid fin and stab, dual elevator servos and 133oz torque servos with a 6v battery. So that all said and done I hope that it is fine. But yes, full throttle loops and silly throttle management is something I will watch! I have a 15x10 prop for starters but will likely up that to a 16x8 zinger If it is too much I may retro fit a 91fx in there but I doubt I will need to. I chose the 120ax due to cost...not much more than the 91!
