nick1881
Joined: 2/23/2008 From: greencastle, PA, USA Status: offline
Hey zip, No bother at all and ill take some pictures tommorrow and show you. to answer a couple questions: -Yes the dimple is where you are going to drill the hole on the pant. - To keep the wheel pant from spinning around the axle will be through it where you drill the hole, and then you can drill a small hole right above the axle(on the landing gear) for a number 2 screw. A piece of hard wood is epoxied to the inside of the pant and the screw goes through the hole on the lg and into the hardwood. Once i take a few pictures it should really make it a lot easier to see what i did. Tuwood did a nice job on his, you might want to check out how he did it too. You might like his way better, but if i recall correctly it is similar if not identical to mine. But ill get some really good detail photos on here tommorrow evening. Nick
